Premium Retractable Caster Assembly
$199.95
Move your MARK effortlessly around the shop—built for convenience, engineered for durability.
Shopsmith Premium Retractable Casters are designed specifically for MARK tools, making it easy to glide your machine from one location to another—even over garage or basement concrete expansion joints.
Built to Last
Constructed from rugged die-cast aluminum with solid steel rods, these casters feature a spring-loaded mechanism with three settings:
Step once to raise your MARK ¼" off the ground—perfect for smooth surfaces
Step twice to increase ground clearance to ½"
Step three to gently lower your MARK back into working position
Includes everything needed to upgrade your MARK:
(4) 3" diameter by 1-¼" wide polyolefin red wheels mounted on rugged ⅜" steel axles with sealed ball bearings for smooth, quiet rolling. The casters swivel 360° for effortless maneuvering.
(2) Caster Brackets
Steel Drill Guide with Drill Bit
Mounting Hardware
Installation Instructions
