Premium Starter Package (for All MARKs except MARK V 500)
$489.95
The Premium Starter Kit for the MARK 7 is an awesome package with everything you need to get started making your dream projects fast. The 27-Piece Kit gives you the ideal collection of accessories to help you enjoy the benefits of each of your MARK 7's key core functions & Save!
The 27 piece Premium Kit for the MARK 7 includes everything in the Basic Starter Kit PLUS the Following:
• Shaper/Drum Fence. A great tool for straight edges on decorative cuts. This part also acts as a back stop for both your infeed and outfeed sides making for greater ease of use.
• 3 Premium Shopsmith Shaper Cutters for decorative edging, joinery and more.
• 3 Shopsmith Carbide Tipped Router Bits. These have been designed for working with hardwoods and laminates in a production or home shop environment. Each features rugged carbide tips to take and hold a keen cutting edge, with infrequent sharpening.
• 8-Pc Lathe Chisel Set. This set will satisfy the majority of your turning needs. Each chisel features a premium-quality high-speed steel blade to take and hold a keen cutting edge under hard use. The eight-piece set includes: 1" Roughing Gouge, 3/4" Roughing Gouge, 1/2" Spindle Gouge, 1" Skew Chisel, 5/8" Skew Chisel, 5/8" Roundnose, 3/16" Parting Tool, and 5/8" Spear Scraper. Enjoy this set to discover what many consider to be the most creative of all woodworking operations!
• 3-3/4" Lathe Faceplate. Perfect for turning bowls, vases, cups and similar types of lathe projects.
• 5-Pc Pro Package Brad Point Drill Bit Set. There's nothing like a brad point drill bit for making clean-sided, perfectly-centered holes in wood and these are among the highest quality bits on the market. Includes 1/4", 3/8", 1/2", 5/8" and 3/4".
• 6 Assorted 12" Sandpaper Discs . You get one coarse, two medium and three fine grit open coat aluminum oxide discs that are long-lasting and resistant to "loading".
Out of stock
