Bandsaw Blades
$39.95
Shopsmith Bandsaw Blades are made from premium-quality silicon carbon steel with precision milled teeth for added sharpness and consistency of cut. These premium blades are induction heat-treated to ensure an even hardness, and feature a special tooth set and rake angle to provide more aggressive cutting with less pressure. This reduces heat build-up, prolonging blade life substantially.
Lifetime Guarantee On Weld Integrity* - If a Shopsmith blade breaks at the weld, we'll replace it for FREE!
Choose The Bandsaw Blade that is Right for Your Project:
- 1/8" Combination Blade (521984) - 14 TPI Raker Tooth - .025" thick: For fine detail work and smooth cuts in wood, plywood, plastics and soft, non-ferrous metals. Cool Blocks are required. 1/4" minimum radius.
- 3/16" Combination Blade (521985) - 10 TPI Raker Tooth - .025" thick: For general craft cuts in wood, plywood, plastics and soft, non-ferrous metals. 3/8" minimum radius.
- 1/4" Combination Blade - 10 TPI Raker Tooth - .025" thick: General purpose blade for wood, plywood, plastics and soft, non-ferrous metals. 1/2" minimum radius.
- 1/4" Combination Blade - .025 -- 14 TPI Raker - For finer finish cuts in wood, plywood, plastics and non-ferrous metals. 3/4-inch minimum radius.
- 1/2" Combination Blade - 6 TPI Raker - Heavy-duty, general-purpose blade for wood, plywood and nonferrous metals. Suitable for wood up to 6-inches thick and metal work on stock up to 1/2-inch thick. 2-inch minimum radius.
- 5/8" Woodcutting Blade - 3-4 Variable TPI - This blade is used strictly for resawing wood up to 6 inches thick and straight cuts only. Variable-spaced tooth design gives a more aggressive cut, less tooth vibration and ultimately, a finer finish cut. Use 1/2" tension setting on Shopsmith bandsaw.
Whether you're cutting large sweeping curves; straight lines; tight, intricate fretwork; resawing thin boards from thick ones; or working with a variety of materials from non-ferrous metals through the softest of woods, Shopsmith has a bandsaw blade to do the job.
*Warranty applies only to original customer on verified purchases made through Shopsmith agents or Shopsmith.com.
Reviews
This blade cuts easily & without drifting; cuts very dense hardwood as easily as softwood.
