top of page
Bandsaw Basic Tune-up Kit
SKU 556083
Price
$79.95
The Perfect Solutions to Get Rid of Squealing, Fix Worn out Tires or Essentials to Make Your Bandsaw Like New Again! \n \nBandsaw Standard Tune-up Kit (556083) \nIf your Bandsaw�s back-up rollers and guides are squealing and/or your blades are not tracking properly and affecting the accuracy of your cuts, this is the kit for you. The Bandsaw Standard Kit includes our Ball Bearing Back-Up Roller Retro-Fit Kit (555074) to eliminate your squealing problem and help your machine run smoother plus two replacement Rubber Bandsaw Tires and a bottle of Tire Adhesive. \n \nBandsaw Complete Overhaul Tune-up Kit (556084) \nThe Bandsaw Complete Overhaul Kit not only fixes issues where Your Bandsaw�s back-up rollers and guides are squealing and/or your blades are not tracking properly and affecting the accuracy of your cuts, but it also addresses another important issue as well. If Your Blades seem to dull quickly (even after installing a new Blade) if your machine seems to generate excessive heat, if it vibrates or if either (or both) of the Blade Wheels can be wiggled easily when the Blades are removed, you likely need the Overhaul Kit. The Bandsaw Overhaul Kit Includes: Our Ball Bearing Back-Up Roller Retro-Fit Kit (555074) to stop the squealing, an upper Wheel and Bearing w/Tire (502691), and a Lower Wheel Assembly with Tire, Bearing and Shaft (509032). \n \nBandsaw Backup Bearing Upgrade is for Older Model Shopsmith Bandsaws With Squealing Bronze Bushing Back Up Rollers, No More Squealing! (555074) \nBeing driven nuts by the squealing back up rollers on your older model Shopsmith Bandsaw? Here's your solution. These high quality, permanently lubricated ball bearing assemblies work with 1/16" through 5/8" blades to reduce blade friction and make your blades last a lot longer. \n \nCompatible with all Shopsmith Bandsaws and has been standard with Bandsaws with serial numbers later than 97932. Kit components replace the bronze bushing upper, lower and auto-track back-up rollers. Easy to install in a matter of minutes and, best of all, No More Squealing! \n \nBandsaw Tire and Adhesive Kit (555644) \nA worn bandsaw drive wheel tire causes vibrations and affects blade tracking. \nThe Bandsaw and Adhesive Kit (555644) Includes: \n� Original Equipment Tire \n� Special Adhesive \n� Instructions. \n \nBandsaw Tire (Tire Only - No Adhesive) (518108) \nBandsaw Tire (only) Original Equipment Tire. Made to last. Heavy-duty, 1/8" thick. Requires Glue. Pair with 55644 Bandsaw Tire and Adhesive Kit to replace both tires on Your Bandsaw to make it run like new.
Loading…
Frequently Bought Together
bottom of page
