Belt Sander Belts 6x48
$24.95
Shopsmith 6 x 48 Sanding Belts are the best on the market. We have 2-different types of belts available for 2-different purposes. Aluminum Oxide (A/O) Belts for general purpose sanding,sharpening and grinding. Ceramic Belts for heavy, long-term sanding and grinding. Ceramic Belts are the ultimate in sanding life and durability. Each type of abrasive is offered in multi-packs of either assorted grits or packs of all the same grit of your choice. Because Ceramic belts have an extended life they are also offered in single packs.
Open-Coat Aluminum Oxide Sanding Belts Offer Extended Durability
Shopsmith open-coat A/O belts cut fast and are more resistant to clogging than their closed-coat counterparts. These are your best choice for your general purpose sanding, sharpening and grinding belts.
Aluminum Oxide Belts Feature:
� Heavy X-Weight Poly-Cotton Cloth Backing for optimum durability under continuous use - plus are flexible enough to be used for contour sanding on the open, back side of the Belt Sander.
� Coarse to Super-fine Grits Available for use with everything from coarse stock removal and heavy grinding to fine surface and detail sanding.
� Bi-Directional Tape Joints for smooth running, quick and easy to belt change.
Shopsmith A/O Abrasives are available in 36 grit, 60 grit, 80 grit, 100 grit, 120 grit, 150 grit, 220 grit, and 320 grits in assorted 3-packs and single grit 3-packs.
Ceramic Belts Cut 4-Times Faster with Less Effort and Last 4-Times Longer Than Standard Abrasives
Shopsmith's premium abrasive products feature Ceramic technology, a combination of the highest quality abrasive grains, mated with the most durable backings to give you the fastest-cutting, longest-lasting abrasives available. These belts are truly the carbide tipped saw blades of the sanding belt world.
Our Ceramic Abrasive Belts Feature:
� Rugged Poly-Cotton Cloth Backings that resist tearing and stretching. Strong, yet flexable
� Bi-Directional, Flush Joints that run smoothly in both directions. Quick to change.
� Heat Resistant Reinforced Joints for maximum seam durability under the toughest of conditions
� Advanced Resin Bonding System for durability and clog-free performance
� Ceramic Grains which stay super-sharp 4-times longer, cut 4-times faster and reduce heat build-up
Start enjoying the benefits of 4-times faster cutting and 4-times longer life with Shopsmith Ceramic Abrasive Belts.
Shopsmith Ceramic Abrasive 6 x 48" Belts are available in 36 grit, 60 grit, 80 grit, 100 grit and 120 grit. Each comes one per package.
Note: We advise you to always wear an N95 (NIOSH-Certified) Respirator when sanding to filter out 95% of airborne particles.
