Shopsmith Power Coupler
$27.95
Make the Connection with the Shopsmith Power Coupler!
The Shopsmith Power Coupler (503574 Power Coupler Only) is made of a virtually unbreakable plastic compound. Each end mates with splined metal Hubs that attach to your MARK?7 / MARK V / MARK 4 / POWER STATION and Special Purpose Tools such as Bandsaws, Planers, Jointers, etc.
Have It Your Way: Buy the Power Coupler by itself or buy a Complete Power Coupler Kit or a Classic Power Coupling Kit!
Note: The Power Coupler Kit is required to connect Special Purpose Tools (SPT's) to your Shopsmith MARK?7, MARK V or MARK 4. (It became a standard part included with all MARK?7 / MARK V's manufactured since April 1985)
Buy a pair of couplers. By buying two, you'll have a spare handy and save!
556135 (2) Shopsmith Power Couplers (Couplers Only)
Shopsmith Complete Power Coupler Kit (505631)
Get everything you need to get started using your Shopsmith Special Purpose Tools in one convenient package!
You'll receive our durable plastic coupler, two 4-splined metal hubs that attach to the upper & lower drive-side spindles on your MARK?7 or Mark V headstock, PLUS both 5/8" & 1/2" 5-splined accessory hubs to conect all your special purpose tools.
Shopsmith Classic Power Coupling Kit (555124)
Order a classic coupling kit. The classic power coupling kit includes the coupler and 2 metal hubs (one each for the upper and lower spindles of your MARK?7 / Mark V headstock).
Note: Special Purpose Tool (Bandsaw, Jointer, etc.) accessory hubs are not included. Order the appropriate accessory hubs you need in the Special Purpose Tool Accessory Hubs section below.
Accessory and Drive Hubs
503572 1/2" SPT Accessory Hub (for Jointer, Jigsaw or Scroll Saw)
503740 5/8" SPT Accessory Hub (for Bandsaw, Belt Sander, Planer or Strip Sander)
Extra Headstock Drive Hubs
503570 Upper Drive Hub Assembly
503738 Lower Drive Hub Assembly
Reviews
With the new change to the company don't assume you should look elsewhere for parts like a used one from ebay or a knock off. Reasnably priced and quick delivery brand new from the source and only a buck or two more than a used or knockoff!
