Sawdust Session Volume 1 VBook
$16.95
Sawdust Session Volume 1 is jam-packed with valuable Tips, all included on this DVD: • Making Mortises with a Mortising Attachment - how to properly set up and use a mortising attachment for a drill press. • Making Mortises on an Overarm Router - See how this unique tool lets you monitor the cut as it progresses, making it much easier to start and stop with precision. • Aligning the Main Table on the Shopsmith MARK V - What you must do to make this critical alignment within a thousandth of an inch. • Precision Sanding with the Conical Sander - Sanding edges perfectly parallel, jointing figured wood, and other tricks with this unique tool. • Choosing and using drill bits - Sort through the hundreds of choices available to you and pick the drill bit best suited for the job. • Vernier Scales for the Stop Collar - This attachment lets you adjust the depth of cut within 1/16" But with these scales, you can get it to within one thousandth! • Ten Cent Mortising Gauge - One thin dime is all you need to properly set up a mortising bit.
Only 7 left in stock
