Precision Ground Scroll Saw Blades (2 Skip Tooth Blades -12 Blades)
$11.95
Shopsmith partners with Olson for Scroll Saw Blades because they manufacture the widest variety of the highest quality Scroll Saw Blades available. All of our Scroll Saw Blades are made with high-carbon, heat-treated steel right here in the USA. We can offer the greatest variety of blades for any application performed on a Scroll Saw. Our blades are engineered to suit a multitude of materials, wood to metal to plastic, bone to balsa. They will cut a wide variety of material thickness from paper-thin veneers to workpieces well over an inch thick. These blades have a tooth count from 46 TPI down to 6 TPI. Blades as thin as .010” for the most delicate cuts you can imagine up to .062” thick for cutting even the toughest of material. Our Precision Ground Reverse Skip-Tooth Blades are the best-of-the-best for both hardwoods and soft as well as other materials such as paper, fiberboard, plywood, bone, Corian and plastic. Olson Precision Ground Blades are made with propriatary process which produces razor-sharp teeth that cut faster and more accurately and provide a smoother, sand-free surface. Unique tooth-geometry and widely spaced gullets minimize burning and provide rapid chip removal. The reverse teeth at the bottom of the blade cut on the upstroke and eliminate underside tear out. Includes: (12) Precision Ground Reverse Skip-Tooth Scroll Saw Blades (Universal #2)
Only 8 left in stock
