Milled Scroll Saw Blades (9 Metal Cutting)
$11.95
Shopsmith�s Scroll Saw Blades are the Smoothest Cutting Blades Available!
Shopsmith partners with Olson for Scroll Saw Blades because they manufacture the widest variety of the highest quality Scroll Saw Blades. They are made of high carbon and heat-treated steel right here in the U.S.A! We can offer the greatest variety of blades for any application a Scroll Saw is required to cut. Our blades are engineered to suit a multitude of materials, wood to metal to plastic, bone to balsa. They will cut a wide variety of material thickness from paper-thin veneers to workpieces well over an inch thick. These blades have a tooth count from 46 TPI down to 6 TPI. Blades as thin as .010� for the most delicate cuts you can imagine up to .062� thick for cutting even the toughest of material.
Milled Metal Cutting Scroll Saw Blades
Metal cutting blades are made of hardened and tempered steel and have more teeth per inch for cutting thin metal and other hard materials. Blades have regular style teeth.
911392 Universal #7 is .041 wide and .019 thick with 30 TPI. Package contains 12 blades.
