MARK V Essentials DVD (Volume 2)
$39.95
Essentials Volume 1 (556063) is a 76-minute video introduction to the Shopsmith MARK V and the first three of its five basic functions. If you’ve been wondering whether or not a Shopsmith Multipurpose Woodworking System is for you, of if you have purchased or inherited a new or used machine and would like to see it put through its paces, this great Nick Engler, top woodworking author and instructor hosted DVD, is most definitely for you.In this video, Nick begins by introducing you to the concept behind this well-known American Legend and describe the main components of the machine and how they function together.From this introduction, Nick will continue with in-depth discussions including:1. How to set-up and use the MARK V Table Saw, including the different blades that are available; how to mount them; positioning the Worktable; making vital adjustments; using safety devices; and working with the Miter Gauge, Rip Fence and optional CrosscutSliding Table.2. How to set-up and use the MARK V Drill Press, including raising the machine into vertical position; adjusting the Worktable for drilling; installing the Drill Chuck and bits properly; using the Rip Fence and Miter Gauge for controlling the workpiece and performing repetitive operations; setting the Depth Stop; adjusting the speed and using the Telescoping Legs for added workpiece support.3. How to set-up and use the Horizontal Boring Machine, including adjusting the Worktable height; using the Rip Fence as a backstop; adjusting the Depth Stop and using the Miter Gauge to ensure perpendicularity.In this second installment of Nick Engler’s MARK V Essentials video, he covers the final two functions of the MARK V PLUS some important, critical maintenance procedures.Nick’s follow-up to our MARK V Essentials, Volume 1 DVD is the perfect companion for the Volume 1 edition. In MARK V Essentials, Volume 2, Nick will cover:4. Disc Sanding with both our standard Flat and our optional Conical sanding discs. He’ll discuss using the Flat Disc at the center of the MARK V Worktable, as well as at the outside edge for both straight and convex edge sanding and how the Lower Saw Guard can be used to keep shop dust at a minimum. He’ll also introduce you to our amazing Conical Disc and the unique operations that only it can perform.5. Lathe Turning, including how to set the MARK V up in Lathe mode, align its components for the best results and mount the workpiece properly.ADDITIONALLY: Nick will cover Critical Maintenance Procedures, including cleaning & lubricating the Smart Motor & locks; Quill; Speed Dial; Worktable & Cariage; Way Tubes; Extension Tubes & locks; Miter Gauge; Rip Fence; Saw Guard; and Lathe Tool Rests & Posts.Note: For the complete MARK V Essentials story, we recommend that you order both Parts 1 and 2 of this video, and have established a special discounted price for ordering both parts.BUNDLE & SAVE (556068)Get both power packed Essentials Volume 1 and Volume 2 for a bundled price and save.
Only 7 left in stock
