Guide Bar 19 Inch W/Hardware & Lit. (for All MARKs)
$39.95
Making precision saw cuts -- guiding workpieces precisely through Molding, Dadoing, Shaping & Routing operations -- and controlling your stock during sanding are all jobs that require the help of a reliable, accurate Miter Gauge. Shopsmith's Miter Gauge is the perfect solution! \n \nThe Miter Gauge Package includes the Miter Gauge and the Safety Grip. \n \nThe Shopsmith Miter Gauge forms the basis for this complete system of work-holding and guiding devices. It offers: \n� A built-in scale that reads from 90� to 30� left and right \n� An adjustable �zeroing� pointer that lets you measure down to 1� increments \n� Adjustable auto-stops at 90� and 45� in both directions \n� A large, knurled knob with through holes (for use with the 5/32" Allen wrench as a lever) to lock the gauge into position. \n� A 1/4" hole that runs through the face (left-to-right) for inserting the optional stop rod. \n� Two 1/4" wide slots in the face for attaching Miter gauge Extensions and other helpful Jigs and Fixtures \n� Two adjustable Nylon Glides on the bottom for smooth sliding and to prevent rocking \n� An expanding Bar to reduce sliding clearance and to lock the Miter bar in in the slot to work as a guide or fence \n� A T-washer in the guide bar used with the T-Slot in the main worktable to keep the miter gauge in the slot for wide cuts and to prevent accidental lift-out \n \nThe Miter Gauge Safety Grip attaches to the miter gauge with a single screw and the top screw-in post. One pound of pressure on the grip exerts five pounds of holding pressure between the safety grip pad and the top of the miter bar to keep the stock from slipping during the cut. Quick-release knob adjusts rapidly for stock up to 4-1/4" thick. \n \nQuick-Clamp Miter Gauge Retro-Fit Kit \nThe MARK V 500 Quick-Clamp Miter Gauge Retro-Fit Kit replaces the thumb-screw adjustment mechanisms on older Shopsmith miter gauges. A REAL TIME-SAVER! \n \nMiter Gauge Stop Rod \nThe Miter Gauge Stop Rod adjusts to make repetitive crosscuts up to 19-1/4" from the saw blade. Includes two set screws for attaching to the miter gauge. \n \n24" Aluminum Miter Gauge Extension \nThe 24"Aluminum Miter Gauge Extension mounts quickly and easily to the face of your Shopsmith miter gauge with two mounting bolts and knurled locking knobs. Stop block (included) adjusts to make repetitive crosscuts up to 24" long. \n \n20" Aluminum Miter Gauge Extension \nThe 20" Aluminum Miter Gauge Extension attaches to your miter gauge face via rear T-Slots with two bolts and knurled knobs. The adjustable stop slides to the left or right in a top-mounted T-Slot and can be flipped up or down when needed. The extension (with stop) slides left or right on the gauge face to allow repetitive cut-offs up to 20" long. \n \nMiter Bars \nMiter Bars are made to fit all MARK work tables, Shopsmith aluminum bandsaw tables and T-Slotted router tables. MARK 7 / MARK V 520, 510, 505 / MARK 4 version includes a removable T-Slot washer. MARK V 500 version does NOT include T-Slot washer. \n \nThe Miter Bar for Jigs & Fixtures includes a steel miter bar with T-Slot washer to prevent accidental lift-out and mounting holes with counterbores for three 1/4-20 by 1/2" long button head screws (included). Also includes three mating 1/4-20 threaded inserts for attaching miter bar to jig or fixture and a hex key for installing threaded inserts.
Reviews
Would be nice to see Shopsmith offer miter slot bars compatible with Incra or new WEN miter gauge. Simple solution to improve table saw. Long time about Shopsmith sold a version of Incra that worked with Shopsmith proprietary slot
