top of page
Extender with Bolts and Spacers (for MARK V 500 Insert and Vacuum Attachment)
SKU 556269
Price
$39.95
Achieving the highest quality, smoothest wood finish must start with a perfectly smooth surface. Achieving that smoothness (especially on a Curved Edge) usually means incrementally sanding raw workpiece edges with coarse, medium and fine grit abrasives. Skip a step and you will end up with poor results.
Without Shopsmith�s Multi-Sand Process, You Would Likely Follow a Normal 3-Step Changeover Process:
1. Install a coarse sleeve to remove the majority of the sawing marks.
2. Repeat the process by removing the coarse sleeve from your drum and replacing it with a medium sleeve.
3. Repeat the process again by replacing the medium sleeve with a fine sleeve and complete your final step.
What if you could cut those three installation steps down to just one � and spend more time sanding and less time changing? You can, thank Shopsmith's Multi-Sand Drum Sleeves!
Shopsmith Multi-Sand Sleeves Eliminate the Changeovers and Get the Job Done Faster!
Here's How It Works:
� Install a 2" high x 2-5/16" diameter fine grit Multi-Sand Sleeve, sliding it all the way to the top of the 6" drum followed by a 2" medium grit sleeve, and finally a 2" coarse grit sleeve.
� Attach the sanding drum to your spindle and you're ready to start sanding.
� Remember, your MARK gives you 4-1/4" of up-down quill travel. That means you can go through all three steps of the sanding process on any piece of stock up to 1" thick by simply moving your quill down for each subsequent step.
With no sleeve changing, nothing could be simpler or faster!\
Multi-Sand Drum Sanding Complete Package Includes:
6" x 2-5/16" Drum Sander
� 1 Each Coarse, Medium, and Fine 2" Long Sanding Sleeves
� Vacuum Attachment
� Vacuum Extender
� Table Insert
Getting Started Is Amazingly Affordable!\nIf you already own the Shopsmith 6" Drum Sander, all you need to get started is a package of our assorted Multi-Sand Sleeves.
If you don't yet own a Shopsmith 6" Drum Sander or any of the optional drum sanding table inserts or vacuum attachments, order the following:
Table Inserts:
� 555119 Drum Sanding Table Insert (for MARK 7 / MARK V 520, 510, 505 / MARK 4)
� 556267 Drum Sanding Table Insert (MARK V 500)
Vacuum Attachments:
� 556257 Drum Sander Vacuum Attachment and Extender (for MARK 7 / MARK V 520, 510, 505 / MARK 4)
� 556265 Drum Sander Vacuum Attachment and Extender (for MARK V 500)
� 556268 Extender (with bolts and spacers) (for MARK 7 / MARK V 520, 510, 505 / MARK 4)
� 556269 Extender (with bolts and spacers) (for MARK V 500)
Note: Extender is required for those who already own the correct drum sander table insert & drum sander vacuum attachment)
Out of stock
Specifications
Extender with Bolts and Spacers (for MARK V 500 Insert)
Loading…
Frequently Bought Together
bottom of page
