40-Piece Complete Pattern Drum Sanding Kit
$179.95
Drum Sanding is used for sanding the inside or outside of curved edges on project workpieces. These drums are as small as �� Diameter up to 2-5/16� diameter and work for many project applications. Shopsmith drums and sleeves range from 6� long down to 2� long to work easily on thick-to-thin stock. The abrasives are Aluminum Oxide (A/O) for strength and durability and Garnet for sharp, fast-cutting edge sanding. All of the Shopsmith 2-5/16� Sanding drums mount directly onto the Quill Spindle with a quick turn of the 5/32� Allen wrench. The rest of these drums are installed in the Drill Chuck and secured with the Chuck Key. There is even a Multi-Sand Drum that uses 3 different grits on the same drum, so changing from coarse to medium to fine is as easy as extending the quill. Below you will find these drums are available as singles or grouped together in convenient packages. No longer will you have unsightly, rough curved edges on your workpieces.
Shopsmith 2-5/16" x 3� Long Drum Sander with Sanding Sleeve
The 2-5/16" Shopsmith drum sander is 3" long with a rubber expansive drum that can be attached quickly to the spindle on Your MARK, Shopsmith Power Station, or the auxiliary spindle on your Shopsmith Belt Sander. Just slip the sleeve on, tighten the expansion bolt, and go to work. The 3� long sleeves are made with tough, long-lasting A/O Abrasive. They come in 6-packs of 60, 80, and 100 Grit sleeves as well as an assorted 6-pack of 2 each 60, 80, and 100 Grit sleeves. Includes: Drum Sander and One Medium Grit Sanding Sleeve.
Out of stock
