1/8 Inch Premium Combination Bandsaw Blade (14 TPI Raker .025" Thick)
$39.95
Shopsmith Premium Bandsaw Blades are fabricated from high-quality silicon carbide steel with precision-milled teeth for superior, long lasting performance. Our premium bandsaw blades are induction heat treated to ensure an even hardness. Shopsmith blades feature a special tooth set and rake angle ensuring consistent cutting with less pressure on a wide variety of materials reducing heat build-up, prolonging blade life. All Shopsmith Premium Bandsaw Blades include a lifetime warranty on weld integrity. Should your bandsaw blade break at the weld, we'll replace it for free for the lifetime of the blade. Shopsmith's 1/8 Inch Premium Combination Blade features a 14 TPI, raker-style tooth set ideal for fine, detail cutting of soft woods, plywood, plastics, and non-ferrous metals. This blade has a 1/4 Inch minimum radius and must be used in conjunction with our Bandsaw Cool Blocks (555374).
Specifications
