1/4 Inch Premium Combination Bandsaw Blade
$39.95
Shopsmith Premium Bandsaw Blades are fabricated from high-quality silicon carbide steel with precision-milled teeth for superior, long lasting performance. Our premium bandsaw blades are induction heat treated to ensure an even hardness. Shopsmith blades feature a special tooth set and rake angle ensuring consistent cutting with less pressure on a wide variety of materials reducing heat build-up, prolonging blade life. All Shopsmith Premium Bandsaw Blades include a lifetime warranty on weld integrity. Should your bandsaw blade break at the weld, we'll replace it for free for the lifetime of the blade. Shopsmith's 1/4 Inch Premium Combination Blade features a 10 TPI, raker-style tooth set ideal for general purpose cutting operations of soft woods, plywood, plastics, and non-ferrous metals. This blade has a 1/2 Inch minimum radius.
Specifications
(1) 1/4" Combination Blade - 10 TPI Raker Tooth - .025" thick: General purpose blade for wood, plywood, plastics and soft, non-ferrous metals. 1/2" minimum radius. Made from premium-quality silicon carbon steel with precision milled teeth for added sharpness and consistency of cut.
