top of page
MARK 7 / MARK V MODEL 520 TABLE SERVICE PARTS
135z
522363
(incl 136-166)
136
515859
MARK 7 / MARK V 520/510/505 Table Rail Knob with Stud
136a
518462
MARK 7 / MARK V520 Table Rail Connector Tube Lock Knob Return Spring
137
501637
Hex Head Screw
138
51410004
139
51409702
140
426370
Screw
141
522371
Front Rail Main Table Assembly (MARK 7/MARK V 520S)
142
515294
Hex Nut with Star Washer
143
518490
MARK 7 / MARK V520 Main Table Rear Rail
144
120392
Flat Washer
145
518460
MARK 7 / MARK V520 Rail to Table Mounting Flat Head Screw
146
518403
MARK 7 / MARK V520 Table Spacer for Rails
147
501633
Washer
148
514620
MARK 7 / MARK V 520/510/505 Main Table Rear Trunnion
149
514130
MARK 7 / MARK V 520/510/505 Front Trunnion
149z
514339
(incl 149-153)
150
514340
MARK 7 / MARK V 520/510/505 Table / Front Trunnion Table Stop Pin
151
514341
MARK 7 / MARK V 520/510/505 Table, Front Trunnion, Stop Pin Compression Spring
152
514466
Flat Washer
153
514342
MARK 7 / MARK V 520/510/505 Front Trunnion Stop Pin Compression Spring Retaining Ring
154
517829
Button Head Cap Screw
154a
514040
Pan Head Screw
155
514115
MARK 7 / MARK V 520/510/505 Tie Bar Guard
156
514634
MARK 7 / MARK V 520/510/505 Main Table Tilt Lock Rod & Shoe Assembly
157
514353
Rip Fence & Table Tilt Lock Compression Spring
158
518372
MARK 7 / MARK V 520/510/505 45-Degree Table Stop Bolt
159
514350
Table Insert Mounting Screw
160
514104
MARK Clamp Shoe
161
120393
Flat Washer
162
514311
MARK 7 / MARK V 520/510/505 Table Indicator Plate
163
514344
MARK 7 / MARK V 520/510/505 Tie Bar & Tube Assembly
163z
514448
(incl 164-166)
164
514447
Table Tilt Lock Nut
165
5042559
Table Tilt Lock Handle
166
502680
Table Tilt Lock Retaining Ring
Search
Service diagram for the Shopsmith MARK tables
bottom of page
