Wood Properties and Speed Conversion Quick Reference Charts
$27.95
Inexpensive, Must-Have Reference Aids That Clearly Belong In Every Shop! \n \nLaminated Quick-Reference Speed and Conversion Chart \nEver wonder about the ideal machine speed for drilling a 1/2" hole into plastic -- for resawing a thick piece of hardwood with your bandsaw -- or for rounding an 8" diameter bowl on the lathe? This chart covers these three operations plus over 300 other operations! \n \nIt covers Sawing � Dadoing � Molding � Drilling � Horizontal Boring � Shaping � Disc Sanding � Drum Sanding � Belt Sanding � Lathe Turning � Routing � Jointing � Planing � Bandsawing � Scroll Sawing and � Strip Sanding and every operation you can perform with Your MARK. \n \nWhether you're machining hardwoods, softwoods, composites, iron, steel, non-ferrous metals, plastic, bone, horn or fibrous material, you get the ideal speed for virtually every imaginable operation and get it fast! \n \nBut Machine Speeds Are Just the Beginning! You'll also find loads of other valuable information in this handy laminated 11"h x 17"w chart. \nThis Powerhouse Includes: \n� Comprehensive Table of Fractional/Decimal/Millimeter Equivalents from 1/64" to 1" by 64ths \n� Decimal Equivalents for Number Drills - most commonly used to drill tapping holes for machine screw sizes 4-40 through 1-4"-28 \n� Decimal Equivalents for Letter Drills - most commonly used to drill tapping holes for machine screw sizes 5/16"-18 through 7/16"-20 \n� Common Tap Drill Sizes For Machine Screws from 6-32 through 1/2"-20 \n� Recommended Wood Screw Pilot Hole Sizes for Body Holes, Lead Holes and Counterbores \n� Properties of the 11 Most Popular Wood Glues \n� Mortise & Tenon Sizing Guidelines for Stock Thicknesses from 1/2" to 2-1/2" \n \nQuestions About Domestic, Exotic or Engineered Woods? Get Your Answers On This Handy Quick-Reference Chart \nThis Laminated Chart Puts a Wealth of Time-Saving Workshop Information Right At Your Fingertips. It's jam-packed with a wealth of information about the many different types of woods we all use to build our projects. Here are just a few examples of the invaluable data that's available to help you select the best woods for the projects you're building in your shop: \n� Which woods are the strongest, hardest & most stable \n� Which are the most rot-resistant for building outdoor projects \n� Which woods are the lightest & heaviest per board foot \n� What should I use for bentwood, marine or carving projects \n� What are the nominal & actual thicknesses & widths of framing or construction grade lumber \n \nIt also includes: \n� A quick reference table of 125 instant board foot calculations for 1", 5/4", 2", 4" & 6" thick lumber in 8', 10', 12', 14' & 16' lengths --PLUS-- the formulas for computing board feet for your own widths & lengths \n� A guide to understanding how interior & exterior grade softwood plywoods are graded; the number & types of defects permitted for each grade; & which grade to use for your different types of projects \n� A table of 30 domestic & exotic toxic woods, how dangerous each can be to your health & the potency of their toxins \n� A table of 16 endangered wood species, which are available & which are not, their origins & common uses \n�A wealth of invaluable information about the three most common engineered wood products (Particleboard, Oriented Strand Board & MDF) --- the primary components of each, the binding agents used, their density, strength, moisture resistance & any special fastening tips \n \nBUNDLE & SAVE \nBuy Both the Speed Conversion and the Wood Properties Quick Reference Charts and Save! \n \nPrinted in full color on heavyweight stock for quick reference and encapsulated inside a plastic lamination for durability.
