Planer/Jointer Sharpening Jig
$109.95
Buy Your Jointer/Planer Knife Sharpener to Pair with Your Conical Sanding Disc
Nicked Planer or Jointer Knives can spoil the appearance of your projects and cost hours (or days) of delay as you sand out the blemishes they'll leave -- or wait while you send your blades out to the sharpening service. But now, this easy-to-use sharpener will save you the time that could be required to sand out those nicks or the expense you could face for having your blades professionally sharpened. Just clamp your knives into the self-aligning jig, grasp the two large handles and use your Shopsmith conical sanding disc to sharpen them to a keen edge. Special nylon glides on the back and bottom edges ensure the guide's smooth travel over Your MARK 7 / MARK V / MARK 4 tabletop and against your rip fence as it holds your Knives at the precise, correct angle while you sharpen them.
This is truly the simple, foolproof way for you to keep your jointer and planer operating at peak performance no matter what happens.
555471 Includes: Complete, step-by-step instructions for set-up and use.
Note: 555471 Requires Shopsmith's Conical Sanding Disc for proper operation.
If You Don't Already have a Conical Sanding Disc, You will need one buy one use the Jointer/Planer Knife Sharpener.
There are two ways to buy: Either buy 555435 Conical Sanding Disc (Disc Only) or buy 555477 Conical Sanding Disc and Special Assorted Abrasives. (1 each 50, 80 and 150).
BUNDLE & SAVE
Buy the Jointer / Planer Knife Sharpening Jig Kit which includes: 555471 Jointer / Planer Knife Sharpener and 555477 Conical Sanding Disc and Special Assorted Abrasives. (1 each 50, 80 and 150).
