top of page
MARK V 510 to MARK 7 Pro Fence Upgrade (for units made in 1986 or later)
SKU 555982
Price
$649.95
Add a more versatile rip fence for improved results and direct-reading scales for greater accuracy!
This Pro Fence System has been engineered to give you even better control, precision and quality performance than you've come to expect from your MARK V 510. The professional-duty self-aligning, Pro Fence System features two interchangeable stainless steel scales for direct-reading of rip cut widths, plus twin locking levers, first one for the infeed end of the fence and the second for the outfeed end to ensure a positive, precise fence lock-down, even when working with large and/or heavy workpieces.
Your new Rip Fence drops straight down onto the fence rails without tipping or fiddling, then slides easily and precisely along the rails on high-tech glides. The fence is easier to square-up than a 510 fence (the alignment screws are easily accessible on the top of the Rip Fence) and the 520 floating tables feature a 3-point locking system to ensure that your fence is always parallel to the blade, unlike the single-point locking system on the Model 510 floating tables.
Your New Rip Fence adds three more heavy-duty T-slots (two on the top and one on each face for attaching even more jigs & fixtures) to your machine. Two new fence rails for the main work table, two new fence rails for the fixed extension table and four new fence rails for your two floating tables, plus all the required rail mounting hardware and a special-built set-up and alignment gauge. Included is the new, wider fence straddler that slides easily on your new wider rip fence for cutting narrow workpieces, and finally a comprehensive Owner�s Manual.
What's included:
  • Larger rip fence is 24-1/2" long x 2-1/2" thick with dual T-slot tracks on the top surface and a T-slot track on each face for mounting accessories such as: rip fence mounted feather board, T-track utility light kit, flip-up rip fence stop.
  • Direct-reading rip fence scales let you set rip cut dimensions in an instant without measurement. Includes two magnetic, stainless steel scales, one 45" long with a zero-point 6-1/2" from the left end and 38-1/2" from the right end - and a second scale 16" long with a zero-point 6-1/2" from the left end and 9-1/2" from the right end.
  • Wider fence straddler to accommodate the 2-1/2� wide rip fence
  • (6) Extruded fence rails for main and extension tables
  • All required fittings and hardware
  • Instruction manual fully describing alignment, maintenance, safety, tips and techniques
  • Special set-up and alignment gauge
Out of stock
Loading…
Frequently Bought Together
bottom of page
