top of page
Lathe Tool Rest Package
SKU 555315
Price
$99.95
Save with the Lathe Tool Rest Package and get all three tool rests for all your bowl and spindle turning needs.
Lathe Tool Rest Package Includes: Curved, L-Shaped (90 Degree) and 4" Specialty Tool Rests.
Lathe Curved Tool Rest (555312)
Rest your Hand or Tools on this Robust, Solid Cast Iron Rest. When using your Shopsmith Lathe, this tool rest can be used to easily craft bowl shaped pieces of wood. It offers You new angles to keep your hands and chisel sturdy. The curved shape lets you reach inside bowls easier and around the outside of a bowl with ease.
Lathe L-Shaped Specialty Tool Rest (555313)
90 Degree Tool Rest accommodates both scraping and shearing techniques. This Tool Rest is perfect for turning bowls, goblets, vases and other projects where you should make flowing, continuous cuts from outside surface to inside surfaces. Will not work on 10-ER and Mark II. Fits Tool Rest supports that have a 3/4" post.
Lathe 4 Inch Specialty Tool Rest (555314)
This Tool Rest lets you position closer to deep coves on a spindle or bowl. Reach farther into bowls for hollowing out, and get close to short spindles while maintaining the same steadiness a larger rest would provide. Will not work on 10-ER and Mark II. Top bevel design allows scraping and shearing. Fits Tool Rest Supports that have a 3/4" Post.
NOTE: Lathe Tool Rest Packages and Parts will NOT work on 10-ER and Mark II except for the Lathe Tool Rest Locking Lever Upgrade (521765) which will work with the 10-ER Only.
ATTENTION: LOW STOCK - DELAYED SHIPPING
Loading…
Frequently Bought Together
bottom of page
