Jointer/Planer Knife Sharpening Jig Kit
$169.95
Buy your Jointer/Planer Knife Sharpener to pair with your conical sanding disc. Nicked planer or jointer knives can ruin the appearance of your projects and cost hours (or days) of delay as you sand out the blemishes they make. To fix your jointer/planer knives, clamp your knives into the self-aligning jig, grasp the two large handles and use your Shopsmith conical sanding disc to sharpen them to a keen edge.
Special nylon glides on the back and bottom edges ensuring the guide's smooth travel over your MARK’s tabletop and against your rip fence as it holds your knives at the precise, correct angle while you sharpen them.
The Jointer/Planer Knife Sharpening Jig Kit includes the following:
- Jointer / Planer Knife Sharpener (555471)
- Conical Sanding Disc and Special Assorted Abrasives, 1 each of 50, 80 and 150 grit (555477)
- Complete, step-by-step instructions for set-up and use
NOTE: The Jointer/Planer Knife Sharpener requires the Shopsmith Conical Sanding Disc for proper operation.
