DC-3300 to DC-6000 Dust Collector Upgrade Kit (DC-3300 with Metal Main Housing)
$629.95
DC-3300 To DC-6000 Performance Upgrade Kit (for DC-3300 with Metal Main Housing)
The DC-6000 includes all the best features from the well-engineered, first generation DC3300 Dust Collector PLUS adds the most important new features including a new 1-1/2 Horsepower Motor with new 6-blade Turbo-Fan and High Efficiency Fan Housing. Count on the DC-6000 to allow you to enjoy virtually dust-free woodworking.
Few things are worse for your working environment and your health than a dusty, messy shop. Dusty floors are slippery, dust in lungs can cause serious health problems, and dusty air can contaminate the entire house. Solve all these problems with the DC-6000.
Shopsmith DC-6000 Dust Collector was engineered specifically as a compact, efficient way to suck the wood dust and shavings out of your running Shopsmith machines before they mess up your shop, equipment, clothes, and home.
Then, when you've finished working, you can turn it into an air-cleaning machine by simply disconnecting the hoses, opening all three of its inlets and turning it on. The DC-6000 removes any lingering airborne particles (as small as 7 microns - only 1 micron with optional 42" Hood) from a 12" x 12" shops in about 10 minutes.
Shop-Vacuum vs. Dust Collector:
Heavy-duty shop vacuums are great for sweeping floors, sucking-up water and other general clean-up jobs. But they can't hold a candle to a dedicated Dust Collector when it comes to capturing large volumes of shavings and superfine dust from woodworking machinery. There's No Contest!
Most shop vacuums are wet/dry units. They need a lot of static pressure to suck up nuts, bolts, water, etc. Dust Collectors, on the other hand, are not made for the heavy stuff. Their job is to snatch 90+% of the lightweight dust and debris from your machinery, before it ever has a chance to get loose and become a problem. To do that job, you need high air flow, or CFM (cubic-feet-per-minute) not static pressure, and that's exactly what Dust Collectors deliver in HUGE quantities. In fact, three times or more CFM than a conventional shop vacuum. When it comes to sucking-up sawdust and wood chips, Dust Collectors reign supreme!
Big Powerful Features:
� New, powerful 1-1/2 HP Motor with up to 98% efficiency
� Still one of the quietest Dust Collectors you will find anywhere ? 74 decibels to be precise
� Heavy-duty construction and amazingly great looking!
� (3) 2-1/2 ports enabling you to connect to three machines at once. Exceptional hookup versatility without reducing air flow (CFM) as you add hoses.
� 1 Ready-to-use 8-foot hose & 2 inlet plugs
� A Huge, heavy-duty, 30-gallon see-through, disposable dust bag. Attached and removed with a few turns of a nut driver
� Oversized wheels and casters make for effortless movement
� No extensions needed with the generous 12-foot power cord
Note: If you are using a Wireless Remote Switch to turn on and off the DC-6000 it must be rated for 15-amps.
Specifications:
� Motor: 8 amp 1-1/2 hp capacitor-start industrial motor
� Airflow: 600 CFM
� Bag Capacity: 30 Gallons
� Dimensions: 21"w x 26"d x 48"h
� Power Cord: 12 feet
� Weight: 64 lbs (approximately)
DC-3300 Performance Upgrade Package will provide all the Power of the DC-6000 1-1/2 HP Motor in your existing DC3300!
� This is much more than a "Motor Upgrade", it is a "Performance Upgrade."
� This upgrade improves the old DC3300 to perform just like the new DC-6000.
� This upgrade includes the 1-1/2 hp Motor, New 6-blade Turbo-Fan, with highly efficient Fan Housing and Motor Housing, pre-assembled and quality tested.
� Complete with new Seals and ready to drop into the DC3300 Main Housing.
� Just unplug and remove the old DC3300 Motor, Fan and Fan Housing Assembly and install the pre-assembled DC-6000 Motor, 6-blade Turbo-Fan, with Fan Housing and Motor Housing.
� Now the Performance in the old DC3300 is the same as the new DC-6000.
What�s Included:
� Easy-to-follow instructions.
� All the Necessary Parts and Hardware to Make Upgrading Your DC3300 a snap!
� New powerful 1-1/2 HP Motor with up to 98% efficiency.
� New Motor Housing to accommodate the new, larger motor.
� For Owners with a DC3300 made prior to 1991 (with the metal main housing) this upgrade kit also provides a new leg with a more convenient switch location, the and the addition of collection bag clips (for easy collection bag changes) in the new fully assembled polymer main housing.
Buy The Right Performance Upgrade Kit for Your Machine:
� DC-3300 To DC-6000 Performance Upgrade Kit (for DC-3300 with Plastic Main Housing) (557092)
� DC-3300 To DC-6000 Performance Upgrade Kit (for DC-3300 with Metal Main Housing) (557094)
Only 5 left in stock
Specifications
� For Owners with a DC3300 made prior to 1991 (with the metal main housing) this upgrade kit also provides a more convenient switch location and the addition of collection bag clips for easy collection bag changes
