Lift Assist (for MARK V made after 1972)
$309.95
Effortlessly raise your Shopsmith MARK V made after 1972 with Lift Assist.
Designed specifically for Shopsmith MARK V tools manufactured after 1972 with the conventional headstock, this Lift Assist system uses a powerful gas cylinder to reduce lifting effort when tilting your machine into vertical position. Whether you're converting to drill press mode or storing vertically, the Lift Assist makes transitions smooth and controlled—reducing strain on your back and improving safety.
Key Features:
Designed for MARK V (post-1972) with conventional headstock
Heavy-duty gas spring supports headstock and carriage
Makes lifting easier, safer, and faster
Perfect for frequent tool conversions or vertical storage
Includes all required mounting hardware and instructions
Fits:
MARK V (manufactured after 1972) with conventional headstock
Does NOT Fit:
MARK V units made before 1972
Any machine with the PowerPro headstock
NOTE: If you own Shopsmith's steel storage cabinets, with the lift-assist only one of them will slide under the MARK 7 / MARK V for storage (if the casters are removed from the steel storage cabinets, two will fit).
Out of stock
ATTENTION: LOW STOCK - DELAYED SHIPPING
