top of page
Here’s a nifty weekend project that will give the kids a great place to excerise their artistic talents, practice their math and leave important messages for parents, as well.
All children love to draw and doodle. Crayons and/or markers on paper are a great choice…but errors made with these materials can be difficult or impossible to correct. On the other hand, colored chalks on a chalkboard like this can be a lot less frustrating…and that can make everything a lot more fun, too.
Just let these easy-to-follow plans guide you to the creation of a project that’s handsome enough to display in any room of the house…and enjoyable enough that your favorite kid (or kids) will look forward to hours on end of self-entertainment. We made this one out of hard maple with contrasting cherry drawer sides. Both of these are durable woods that are a true joy to work with.
Building The Framework
Be sure to select stock that’s of a consistent, 3/4″ thickness. If you have difficulty doing so and own a thickness planer, be sure to plane the stock for the stiles and rails (A,B,C) to 3/4″ and cut them to size, according to the Bill Of Materials. If you are going to plane your own stock, joint one edge of these pieces first, then run them all through your planer at the same time. This way, you’re certain to get the straightest, most consistently thicknessed stock possible. Note that the inner rail (C) is 1/2″ wider than the other two rails (B).
FRAME
A
Stiles (2)
3/4 x 2 x 28
B
Rails (2)
3/4 x 2 x 36
C
Inner Rail (1)
3/4 x 2-1/2 x 33
DRAWER BOX
D
Top (1)
1/2 x 5 x 36
E
Back
1/2 x 5 x 36
F
Partitions (2)
1/2 x 5 x 3-1/16
G
Sides (2)
1/2 x 5 x 3-9/16
DRAWERS
H
Sides (6)
1/2 x 2-1/2 x 5
I
Fronts (3)
1/2 x 2-1/2 x 11-5/16
J
Backs (3)
K
Bottoms (3)
1/4 x 4-7/16 x 10-11/16
L
Runners (6)
1/32 x 1/2 x 4-1/2
HARDWARE
Chalkboard (1)
1/4 x 21-1/8 x 32-5/8
Wooden Drawer Pulls (3)
#8 x 1-1/4″ Flathead Wood Screws (5)
#6 x 5/8″ Wood Screws (8)
Helpful Items
Router Package (Router Chuck, Shield, Bits)
Using your dado or router setup, cut a 1/4″ deep by 3/8″ wide rabbet along the inside back edges of the stiles (A), top rail (B) and inner rail (C) to accept your 1/4″ thick chalkboard. NOTE: If you’re using a purchased chalkboard that’s thicker than 1/4″, adjust your rabbet depth accordingly.
Glue and assemble the stiles (A), rails (B) and inner rail (C) to create the framework. Be sure to check carefully for squareness at all joints and set aside to dry.
ree
Building The Drawer Box And Drawers
Once again, if you have a thickness planer, begin by planing all stock you plan to use for pieces D through J to the indicated 1/2″. Next, joint and cut all the common widths for the drawer box and drawers, then cut all the pieces to length, according to the Bill Of Materials.
IMPORTANT: Since you’ll be using finger lap construction for these pieces, it would be a good idea for you to rip the drawer box sides (G) to about 1/16″ wider than indicated…and crosscut pieces D,E,H,I and J to about 1/16″ longer than indicated. This will allow the fingers of your joints to protrude about 1/32″ past their mating workpieces when assembled. These protruding fingers can then be sanded flush once the glue-up has dried.
ree
Creating the finger joints can accomplished with the aid of a special finger lap fixture…which can be used with your dado or router table setup. We used the dado setup to make our chalkboard.
Configure your dado setup, you’ll need to make a finger lap fixture for cutting 1/2″ fingers, instead of the 3/8″ fingers in the linked article. Be sure to cut each finger about 1/32″ longer than 1/2″ (or 17/32″). This will allow the ends to be sanded flush once everything is assembled. Start by cutting the joints for the drawer box top, bottom and sides (D,E & G) then, cut the fingers for the drawer fronts, backs and sides (I,J & H).
Next, cut the 1/4″ deep cross-grain dadoes in the drawer box top and bottom (D & E) to accept the drawer partitions (F). We used the dado setup to cut ours and for appearance purposes, made them “blind” in the front of the box. If you use this approach, you’ll have to use your bandsaw or scroll saw to carefully remove the front edges of each partition so it fits into the blind dado. As an alternative, you could cut also these stopped grooves with your router and a 1/4″ straight bit.
Sand the inside surfaces of all drawer box pieces and dry fit. When you’re sure everything fits properly, disassemble the box, apply glue and clamp together. Check for squareness, wipe away any excess glue immediately with a damp cloth and set the box aside to dry.
Re-configure your dado setup to make a 1/4″ wide x 1/4″ deep cut and rout the grooves 1/4″ up from the inside bottoms of the drawer fronts (I), backs (J) and sides (H) to hold the drawer bottoms (K). IMPORTANT: Be careful to stop these grooves before they reach the fronts and backs of the drawer sides (H) or the drawer bottoms will show through when assembled. Again, as an alternative, these stopped grooves could also be cut with a router set-up and 1/4″ straight bit.
Cut the drawer bottoms (K) to size from 1/4″ birch or maple plywood…or hardboard (Masonite), if preferred. Test assemble all drawer pieces, disassemble, glue, clamp, check for squareness, wipe off any excess glue with a damp cloth and set aside to dry.
Once the assembled drawer box and drawers have dried completely, carefully sand all assemblies smooth and flush with a belt sander, then finish sand them with fine sandpaper. Be sure to remove any sharp edges or corners that could injure children.
Rout a 1/4″ deep by 3/8″ wide rabbet around the inside back of the frame to accept the chalkboard. Square the corners with a chisel.
The Chalkboard
Ready-made chalkboards are available through office supply and specialty stores, or, if you prefer, you can make your own by spraying tempered hardboard (Masonite) with a special chalkboard paint that’s available at craft stores.
Assembly
Attach the completed drawer box assembly to the frame assembly with #8 x 1-1/4″ wood screws. Drill pilot holes in the chalkboard and frame assembly to accept #6 x 5/8″ wood screws but do not attach them at this time. Cut and glue the runners (L) to the bottoms of the drawers. These thin, 1/32″ x 1/2″ x 4-1/2″ strips will make the drawers slide easier and give you an equally spaced gap around all drawers.
If you like, you can add the decorative apple and “ABC” appliques that are cut on your scroll saw from 1/4″ plywood or Masonite. Paint them with a high gloss enamel, then use the same enamel to paint the matching drawer pulls.
Finish the entire chalkboard project (not the actual chalkboard) with a coat of semi-gloss polyurethane. Mount the chalkboard into the frame, attach the appliques and insert the drawer pulls
Using your dado setup, cut the 2″ long x 3/8″ deep lap joints in the ends of the stiles (A) and rails (B), as shown. If you make these joints about 1/32″ or less wider than the indicated 2″, you can sand the joints off flush once you’ve assembled the framework.CAUTION: Using the dado setup requires working without the upper saw guard. Be extremely careful when performing this operation.
Next, lay out and cut the mortises and tenons for attaching the inner rail (C) to the stiles (A). The tenons on each end of the inner rail (C) should be 1/4″ thick by 2″ long by 1/2″ deep. Now, cut the mortises using your Shopsmith Hollow Chisel Mortising setup or your Router setup with a 1/4″ straight bit. If you don’t own either of these setups, you can drill your mortises out with a 1/4″ brad point bit, then clean them up with a bevel-edged wood chisel. To keep the tenons from “bottoming-out”, make the mortises just slightly deeper than the 1/2″ tenons — 9/16″ is about right. Dry fit the frame assembly to be sure everything goes together properly.
bottom of page
