MiterSet Standard & Segment Set (Exclusively Made for Shopsmith)
$239.95
One of the most common headaches in woodworking is making accurate miter cuts. Whether you're creating unique segmented wood pieces, constructing a picture frame, or doing high-end finish work, a well-cut joint is easy to appreciate. You may be thinking two things are necessary for a no-gap miter joint:
1) A correctly calculated and set miter angle;
2) Pieces cut to the right length.
Getting the right length is achieved with accessories like the 24" Aluminum Miter Gauge Extension, the 20" Aluminum Miter Gauge Extension, or the Shopsmith miter stop rod. But, until now, getting the correct angle has been more difficult and time consuming.
The Solution: The MiterSet!
The MiterSet Standard stands out with accurate and fast set-up at ½ degree increments, eliminating concerns about how accurately you’ve set-up your Miter Gauge indicator plate. With the MiterSet Standard, just place one pin in the zero hole and the other in the hole for the desired angle. The holes are clearly labeled with large, easy-to-read numbers giving the angle at every 5 degrees. For angles that are not a multiple of 5 degrees, you'll use the included detent bar to add or subtract up to 2 ½ degrees, in ½ degree increments. Then, loosen your miter gauge lock. Place your miter gauge bar in the MiterSet slot (which was made specially for an accurate fit of your Shopsmith miter gauge bar). Slide your miter gauge against the pins, and then relock your miter gauge. That quickly, your miter gauge will be flawlessly set to the angle you need for your project.
MiterSet Segments For Segmented Turnings - No Math Required!
Normally, when cutting segments, you'd have to calculate the angles. Or, maybe you would need to find your look-up chart to determine the angle you need based on the number of sides in your project. The MiterSet Segment jig eliminates the need for these tedious steps, making it effortless.
Here's How it Works.
• Plug in the base pin;
• Plug the 2nd pin in the hole clearly labeled with the number of sides.
• That's it, the MiterSet has selected and set the correct angle. All that is left to do, is again to place your miter gauge in the slot and slide the miter face against the pins to set the exact angle.
You save the frustration, trial-and-error, and wasted wood that comes with a conventional approach.
Includes: MiterSet Standard & Segments, (2) Pins, Detent Bar (Standard jig only), Padded Protective Case, and Instructions.
Reviews
The MiterSet Standard & Segment Set is an outstanding product. No matter how you try to set an accurate miter angle, you will fail to some degree. With the MiterSet tool, the task of setting a miter gauge angle is quick and accurate only taking seconds to set. This product keeps with the high quality standers of all Shopsmith tools. I would recommend the MiterSet Standard & Segment Set for all shops.
