top of page
MiterSet Segments (Exclusively made for Shopsmith)
SKU 556459
Price
$129.95
MiterSet Segments For Segmented Turnings - No Math Required!
Normally, when cutting segments, you'd have to calculate the angles. Or, maybe you would need to find your look-up chart to determine the angle you need based on the number of sides in your project. The MiterSet Segment jig eliminates the need for these tedious steps, making it effortless.
Here's How it Works.
• Plug in the base pin;
• Plug the 2nd pin in the hole clearly labeled with the number of sides.
• That's it, the MiterSet has selected and set the correct angle. All that is left to do, is again to place your miter gauge in the slot and slide the miter face against the pins to set the exact angle.
You save the frustration, trial-and-error, and wasted wood that comes with a conventional approach.
Bundle and save with the MiterSet Standard & Segments Set (556461)
Loading…
Frequently Bought Together
bottom of page
