Save 15% on everything you need! SAVE NOW
Scroll Saw SPT Kit
555369
$599.95
$509.96
SAVE 15%
STURDY. LIKE NO OTHER.
The Shopsmith Special Purpose Tool (SPT) Power Stand is dressed-to-impress with custom-made, heavy-duty steel construction. The heavy-gauge-steel tapered legs are larger at the top to support the weight of all your Shopsmith Special Purpose Tools securely and run with less vibration.
Get The Shopsmith Power Stand for each of your Shopsmith special purpose tools including Bandsaw, Belt Sander, Jointer, Scroll Saw, & Strip Sander.
Shopsmith's all-inclusive, machine-specific power stands give you ready-to-go woodworking convenience for your Shopsmith special-purpose tools! No need to switchover each time you want to use one of your special purpose tools just power up whenever you are ready by using your power stand.
With your Shopsmith Power Stand, there is no more lifting back and forth.
- Small footprint - just store in a corner and slide it out as needed.
- Made exclusively for the Shopsmith woodworking system with sturdy all steel construction powder coated for durability.
- A heavy-euty, 1.25 service factor, 3/4 HP 11.3-amp motor ready to deliver an additional 25% performance output, on-demand, to handle even the toughest jobs with ease
