SHOP Discounts on Bandsaws & Accessories! SAVE NOW
6 Inch Carbide-Tipped Stack Dado Set
556222
$199.95
When You Want Precise, Chip Free Dado, Rabbets and Groove Cuts in Tough Materials, This Premium, Carbide-Tipped Dado Set Delivers!\n\nThe Premium Quality 6" Carbide-Tipped Stack Dado Set is a stacked dado set cuts precise splinter-free dadoes or grooves in particleboard, MDF, laminates and other tough materials. When you need dadoes or grooves in any of today's tough composite materials, nothing beats the durability of carbide and our DADO Set, made by CMT, a Shopsmith valued Supplier, fills the bill!\n\nThe wide carbide tips on the outer blades provide plenty of clearance to prevent binding and help you get the most power from your Shopsmith. Their teeth feature an alternate top bevel grind to shear the cut cleanly with a flat grind on every other tooth for a flat bottom cut.\n\nThe anti-kickback design greatly reduces the chance of overfeeding the workpiece and creating a kickback. This is feature is very important with a dado because of the amount of material being cut. This Precision Dado Set is designed to set a new standard in performance. \n\n6 Total Chippers Included:\n� Anti-kickback design to reduce the possibility of overfeeding that can occur when cutting mass material\n� Splinter-resistant cuts in veneer plywood, melamine and soft + hardwoods\n� Four-tooth chippers that keep the cut flat & virtually free from tear out\n� 3/32� chipper made especially for undersized plywood\n� Shim sets included for cuts between 1/4� and 29/32�\n� Material: softwood, hardwood, plywood, melamine\n� Finish quality: �Excellent� for ripping wood and plywood and �Good� for ripping and crosscutting plywood\n� 6� Diameter\n� 5/8� Bore\n� 20 Teeth\n� Chippers are flat top & blades are alternate top bevel \n� -5 degrees Tooth hook angle\n\nBUNDLE & SAVE! \nBuy the Complete Package and Save instead of purchasing each item individually at a higher cost.\n\nDado Package for All MARKs (except MARK V 500) \nThe Complete Dado Package for all MARKs (except MARK V 500) Includes: Dado Set, Dado Arbor, and Dado Table Insert. Buy everything you need to cut Dado�s, Rabbets and Grooves in Your Projects on Your Shopsmith MARK. Specifically designed for MARK 7, MARK V (except MARK V 500) and MARK 4.\n\nThis package includes the Carbide Tipped Precision Stacked Dado Head in a storge Case, A matching 5/8� Dado Arbor that is used to hold the Dado Head to make any width Dado, Rabbet or Groove cut you need. A Table Insert with a generous 1-1/4� throat opening for maximum adjustment and workpiece Support \n\nDado Package for MARK V 500.\nThe Complete Dado Package for you MARK V 500 Includes: Dado Set, Dado Arbor, and Dado Table Insert. Buy everything you need to cut Dado�s, Rabbets and Grooves in your Projects on you Shopsmith MARK V 500. \n\nThis package includes the Carbide Tipped Precision Stacked Dado Head in a storge Case, A matching 5/8� Dado Arbor that is used to hold the Dado Head to make any width Dado, Rabbet or Groove cut you need. A Table Insert that will be cut to size, matching your cut for maximum workpiece Support \n\nDado Arbor\nThe 5/8� Dado Arbor that is used to hold the Dado Head to make any width Dado, Rabbet or Groove cut you need. \nHere's a great all-around arbor for use with dado blades or the Shopsmith Molder Head. Includes a 1-7/8" long 5/8" diameter threaded shaft, two steel washers, a 3/4" thick spacer, a locking tongue-washer, and a hex nut. Fits MARK 7 and all other MARK V models. Having extras allows you to have a variety of tools ready to go to work on a moment's notice without bothersome change-over.\n\nNote: Cannot be used with regular saw blades, see saw blade arbors here .\n\nDado Insert (All marks except MARK V 500)\nReplaces sawing insert during dadoing operations to allow an opening in the Table for Dado Blades and supports the workpiece. Made of pressure-cast aluminum alloy with a generous 1-1/8 inch wide slot that adapts to all Dado widths with added room for adjustment.\n\nBlank Insert (for Dado Cuts on the MARK V 500)\nThis Heavy-duty Polymer Table Insert replaces the sawing insert in the main Worktable and gives you maximum work piece support and operator safety. Now you can create your own narrow or wide kerf slots when cutting Dados Rabbets or Grooves without dulling your dado blades. When cut to fit the Dado Set, this Table Insert Supports the workpiece completely around the cut for maximum support. This close fit to the workpiece reduces splintering and kickback.\n\nNOTE: 555500 will not fit ER, MARK II, MARK VII, MARK 7, MARK V 520, 510, 505 or MARK 4. MARK V 500 only.\n\nColor-Coded Polymer Slotted Dado Shim Set\nThis set of 14 special shims will provide practically unlimited adjustments (from .002-inch to .138-inch) to the width of your stack dado cuts. Made of a special oil and grease-resistant polymer that won't swell, wrinkle or buckle, each features a 3/8-inch wide slot from edge to the 5/8-inch arbor hole, to easly slide the shim into place around the threaded arbor shaft.Each different shim size is color-coded for quick recognition.\n\nIncludes: � Four Orange Shims (.002-inch thick) � Two Purple Shims (.005-inch thick) � Four Navy Shims (.010-inch thick) and � Four Black Shims (.020-inch thick) in a � handy, see-through plastic storage box.
