Shopsmith MiterPro Assembly
$149.95
Tired of not-so-perfect miters? The Shopsmith Miter-Pro will put an end to that problem!
The Shopsmith Miter-ProTM gives you precise, tight-fitting miters every time. Its precision machined 90-degree working surface ensures accurate 45-degree complementary angle faces to the table saw blade. Cut half of your mitered corner with one of your adjoining work surfaces, then cut your second piece against the other. You'll get perfect 90-degree corners every time.
No more trial cut after trial cut, fiddling around with a simple task that this amazing tool makes possible in a matter of seconds. The Miter Pro's non-skid abrasive faces combined with the Stop Block hold the stock firmly in place without moving while you make your cuts. The infinitely adjustable Stop Block for making duplicate cuts to exact lengths on stock up to 24-inches long.
Includes 10-inch and 24-inch-long extension fences for optimum stability when working with long pieces. Replaceable, nonskid abrasive on both fences safely keeps stock from “creeping” during cuts. Order an additional 24" aluminum miter gauge extension (555429) and you can have two 24" working faces with adjustable stops for even more convenience.
Out of stock
