Complete Miter Gauge Package with Safety Grip
$139.95
Making precision saw cuts -- guiding workpieces precisely through molding, dadoing, shaping & routing operations -- and controlling your stock during sanding are all jobs that require the help of a reliable, accurate miter gauge. Shopsmith's Miter Gauge is the perfect solution!
The Miter Gauge Package includes the Miter Gauge and the Safety Grip.
The Shopsmith Miter Gauge forms the basis for this complete system of work-holding and guiding devices. It offers:
• A built-in scale that reads from 90° to 30° left and right
• An adjustable “zeroing” pointer that lets you measure down to 1° increments
• Adjustable auto-stops at 90° and 45° in both directions
• A large, knurled knob with through holes (for use with the 5/32" Allen wrench as a lever) to lock the gauge into position.
• A 1/4" hole that runs through the face (left-to-right) for inserting the optional stop rod.
• Two 1/4" wide slots in the face for attaching Miter gauge Extensions and other helpful Jigs and Fixtures
• Two adjustable Nylon Glides on the bottom for smooth sliding and to prevent rocking
• An expanding Bar to reduce sliding clearance and to lock the Miter bar in in the slot to work as a guide or fence
• A T-washer in the guide bar used with the T-Slot in the main worktable to keep the miter gauge in the slot for wide cuts and to prevent accidental lift-out
The Miter Gauge Safety Grip attaches to the miter gauge with a single screw and the top screw-in post. One pound of pressure on the grip exerts five pounds of holding pressure between the safety grip pad and the top of the miter bar to keep the stock from slipping during the cut. Quick-release knob adjusts rapidly for stock up to 4-1/4" thick.
