DC-6000 Dust Collector
$1,049.95
The heavy-duty DC-6000 is the strong silent type you're sure to love!
The DC-6000 includes all the best features including a new 1-1/2 horsepower motor with new 6-blade turbo-fan and high efficiency fan housing. Count on the DC-6000 to allow you to enjoy virtually dust-free woodworking.
Few things are worse for your working environment and your health than a dusty, messy shop. Dusty floors are slippery, dust in lungs can cause serious health problems, and dusty air can contaminate the entire house. Solve all these problems with the DC-6000.
Shopsmith DC-6000 Dust Collector was engineered as a compact, efficient way to suck the wood dust and shavings out of your running Shopsmith machines before they mess up your shop, equipment, clothes, and home.
When you've finished working, you can turn it into an air-cleaning machine by simply disconnecting the hoses, opening all three of its inlets and turning it on. The DC-6000 removes any lingering airborne particles from a 12' x 12' shop in about 10 minutes.
Big Powerful Features:
- New, powerful 1-1/2 HP Motor with up to 98% efficiency
- Heavy-duty construction
- (3) 2-1/2 ports enabling you to connect to three machines at once. Exceptional hookup versatility without reducing air flow (CFM) as you add hoses
- 1 Ready-to-use 8-foot hose an 2 inlet plugs
- 1 heavy-duty, 30-gallon see-through, disposable dust bag
- Oversized wheels and casters made for effortless movement
- No extensions needed with the generous 12-foot power cord
Specifications:
- Motor: 8 amp 1-1/2 hp capacitor-start industrial motor
- Airflow: 600 CFM
- Bag Capacity: 30 Gallons
- Dimensions: 21"w x 26"d x 48"h
- Power Cord: 12 feet
- Weight: 64 lbs (approximately)
Hand-assembled in Dayton, Ohio.
Out of stock
Specifications
� Motor: 8 amp 1-1/2 hp capacitor-start industrial motor
� Airflow: 600 CFM
� Bag Capacity: 30 Gallons
� Dimensions: 21"w x 26"d x 48"h
� Power Cord: 12 feet
� Weight: 64 lbs (approximately)
