Belt Sander Belts 3x21
$22.95
Shopsmith Sanding Belts are the best on the market. Ceramic Belts for heavy, long-term sanding and grinding. Ceramic Belts are the ultimate in sanding life and durability. Each size of abrasive belt is offered in multi-packs of either assorted grits or packs of all the same grit of your choice. Because Ceramic belts have an extended life they are also offered in single packs.
Ceramic Belts Cut 4-Times Faster with Less Effort and Last 4-Times Longer Than Standard Abrasives
Shopsmith's premium abrasive products feature Ceramic technology, a combination of the highest quality abrasive grains, mated with the most durable backings to give you the fastest-cutting, longest-lasting abrasives available. These belts are truly the carbide tipped saw blades of the sanding belt world.
Our ceramic abrasive belts feature:
� Rugged Poly-Cotton Cloth Backings that resist tearing and stretching. Strong, yet flexable
� Bi-Directional, Flush Joints that run smoothly in both directions. Quick to change.
� Heat Resistant Reinforced Joints for maximum seam durability under the toughest of conditions
� Advanced Resin Bonding System for durability and clog-free performance
� Ceramic Grains which stay super-sharp 4-times longer, cut 4-times faster and reduce heat build-up
Start enjoying the benefits of 4-times faster cutting and 4-times longer life with Shopsmith Ceramic Abrasive Belts.
Shopsmith Ceramic Abrasive Belts are available in various size and grits.
Note: We advise you to always wear an N95 (NIOSH-Certified) Respirator when sanding to filter out 95% of airborne particles.
