141
514667
MARK V 510/505 Main Table Tube & Welded Studs
142
515294
Hex Nut with Star Washer
145
514440
MARK V 510/505 Table Tube Jack Screw
146
514101
MARK V 510 Table Tube Spacer
148
514620
MARK 7 / MARK V 520/510/505 Main Table Rear Trunnion
149
514130
MARK 7 / MARK V 520/510/505 Front Trunnion
150
514340
MARK 7 / MARK V 520/510/505 Table / Front Trunnion Table Stop Pin
151
514341
MARK 7 / MARK V 520/510/505 Table, Front Trunnion, Stop Pin Compression Spring
153
514342
MARK 7 / MARK V 520/510/505 Front Trunnion Stop Pin Compression Spring Retaining Ring
154
517829
Button Head Cap Screw
155
514115
MARK 7 / MARK V 520/510/505 Tie Bar Guard
156
514634
MARK 7 / MARK V 520/510/505 Main Table Tilt Lock Rod & Shoe Assembly
157
514353
Rip Fence & Table Tilt Lock Compression Spring
158
518372
MARK 7 / MARK V 520/510/505 45-Degree Table Stop Bolt
159
514350
Table Insert Mounting Screw
162
514311
MARK 7 / MARK V 520/510/505 Table Indicator Plate
163
514344
MARK 7 / MARK V 520/510/505 Tie Bar & Tube Assembly
164
514447
Table Tilt Lock Nut
165
5042559
Table Tilt Lock Handle
166
502680
Table Tilt Lock Retaining Ring
