Find Your Part
- Use the zoom tool, mouse wheel, or pinch to zoom on the diagram.
- Click/touch and drag on the diagram to find your part.
- Click/tap on the reference number in the diagram, or enter it here to filter the parts list table below.
Show Part
Need Help?
Call Shopsmith U.S. Based Customer Care — 937-890-5197Monday - Friday 8:30 am to 4:30 pm Eastern Time.
Email Customer Care — customerservice@shopsmith.com
Parts List:
Ref # | Part # | Description |
1 | 518377 | Strip Sander Cover |
2 | 516232 | |
3a | 516826 | |
3 | 516825 | |
6 | 516421 | |
7 | 515403 | |
8 | 126335 | Carriage Bolt |
9 | 514040 | Pan Head Screw |
10 | 515399 | Strip Sander Front Cover Hinge |
11 | 274737 | Hex Nut |
12 | 515382 | Strip Sander Frame |
13 | 515610 | Strip Sander Hinge Mounting Screw |
14 | 515805 | Shoulder Screw |
15 | 514204 | Hex Nut |
16 | 518122 | Strip Sander Idler Wheel Washer |
17 | 516399 | |
18 | 515423 | Strip Sander Wheel Guard |
19 | 515417 | |
20 | 515401 | Strip Sander Tracking Wheel Retaining Ring |
21 | 513971 | Socket Head Cap Screw |
22 | 504267 | Flat Washer |
23 | 515402 | Strip Sander Tracking Wheel Wheel Bracket |
24 | 515427 | Strip Sander Tracking Knob with Stud |
25 | 515392 | Strip Sander Drive Wheel & Bearing Assembly |
26 | 513809 | Socket Head Cap Screw |
27 | 502726 | Bandsaw Lower Wheel Bearing Retainer |
28 | 515309 | Warning Label |
29a | 514985 | Strip Sander Table Tilt Trunnion Spacer |
29 | 515408 | Strip Sander Tilting Table Trunnion Guide |
30 | 513201 | Socket Head Screw |
31 | 222458 | Allen Set Screw |
32 | 5035769 | |
33 | 513623 | Pan Head Screw |
34 | 502885 | Depth and Angle Pointer |
35 | 517829 | Button Head Cap Screw |
36 | 515395 | Strip Sander 1" Wide Flat Platen |
37 | 515397 | Strip Sander 1/2" Wide Flat Platen |
38 | 515396 | Strip Sander 1/2" Radius Curved Platen |
39 | 514642 | Knob with Stud |
40 | 222460 | Set Screw |
41 | 515380 | Strip Sander Table |
42 | 126315 | Carriage Bolt |
43 | 503782 | Knurled Nut |
44 | 514746 | Lathe Duplicator Template Mounting Set Screw |
45 | 102634 | Hex Nut |
46 | 517829 | Button Head Cap Screw |
47 | 515418 | Strip Sander Tilting Table Trunnion |
48 | 514490 | Fender Washer |
49 | 513739 | Flat Washer |
50 | 515394 | Strip Sander Table Locking Knob & Shaft |
51 | 515472 | Order replacement belts as accessories |
52 | 5137769 | Eccentric Post 8 Inch (for Strip Sander) |
53 | 515568 | Strip Sander Front Cover Latch-Clip |
