Mark Mounted Planer Service Parts
Find Your Part
  • Use the zoom tool, mouse wheel, or pinch to zoom on the diagram.
  • Click/touch and drag on the diagram to find your part.
  • Click/tap on the reference number in the diagram, or enter it here to filter the parts list table below.
Show Part
Need Help?
Call Shopsmith U.S. Based Customer Care — 937-890-5197
Monday - Friday 8:30 am to 4:30 pm Eastern Time.
Email Customer Care — customerservice@shopsmith.com
Parts List:
Ref # Part # Description
1 513393 Planer Anti-Kickback Assembly Long Tube Spacer
2 na Washer
2 513794 .031" Thick Shim Washer
3 513369 Planer Anti-Kickback Wedge
4 513394 Planer Anti-Kickback Assembly Short Tube Spacer
5 513395 Planer Anti-Kickback Rod
6 513385 Planer Sprocket-Locking Cotter Pin
7 na Pivot Arm
8 na Special Washer
8 513733 Planer Special Washer
9 na Pivot Screw
10 555115 Planer Serrated Steel Infeed Roller Upgrade
11 513391 Planer Feed Assembly Woodruff Key
12 na Spacer Washer
12a 514534 Planer Outfeed Roller Kit
13 502899 Jointer Cutter-Head Knife Leveling Screw
14 502051 Set Screw
15 5035769
16 na Ball Bearing
17 513406 Planer Feed Motor Mounting Screw
18 513363 Planer Cutterhead Wedge
19 505982 Planer Knives (Set of 3)
20 na Cutterhead
21 na Chip Deflector
27 51413703 Planer Elevating Crank Assembly
28a na Special Washer
28 514036 Planer Table Connector
29b 513794 .031" Thick Shim Washer
29c 51398901 Locking Set Screw
29a 513857 Jointer Swing Guard Lock Nut
29 51399401 Planer Table Locking Set Screw
30 513397 Planter Table Elevating Screw
31 514039 Planer Table with Stainless Steel Skin
34 514037 Planer Table Connector, Barrel Nut
35 513380 Planer Stock Thickness Scale Pointer
36 513986 Pan Head Screw
37 513730 Planer Tie Bar and Bushings
38 na Shim Washer
39 na Tension Adjustment Sprocket
40 na Roll Pin
41 513387 Planer Table Elevating Chain
42 513414 Planer Knife Setting Gauge
43 51368601
44 51368604 3/16" Short Arm Hex Wrench
45 513391 Planer Feed Assembly Woodruff Key
45 51368607 1/8" Hex Short Wrench
46 51368605 3/32" Hex Wrench
47 513348 Planer Front Top Cover
48 514207
49 513191 Socket Head Screw
49a 513386 Socket Head Cap Screw
50 120380 Washer
50 120380 Washer
50 120380 Washer
51 51336001 Planer Drive Hub and Coupling Cover
52 na Left End Frame
53 513782 Screw
54 449613 Screw
55 51372304 Shopsmith Logo Name Plate
56 518386 Planer Cover with Warning Label
56a 516540
57 513738 Planer Rear Cover Pivot Screw
58 513752 Planer Outfeed Cover Logo Pivot Stud Retaining Ring
59 513376 Planer Feed Roller Tension Screw
60 513389 Planer Feed Roller Tension Spring
61 na Right End Frame
62 513720 Planer Rear Cover Latch
63 513721 Planer Rear Cover Latch Spring
64 513722 Planer Rear Cover Latch Shaft
65 na Spring Washer
66 na Bearing Support
67 513739 Flat Washer
68 120214 Lock Washer
69 513795 Screw
70 513402 Planer Feed Roller Gear
71 513857 Jointer Swing Guard Lock Nut
72 513746 Planer Stock Thickness Scale
73 513381 Planer Chain Tension Sprocket
74 513375 Planer Chain Idler Sprocket Pivot Screw
75 513793 Planer Chain Tensioning Bracket Mounting Screw
76 513368 Planer Chain Idler Sprocket Bracket
77 120392 Flat Washer
78 115546 Lock Washer
79 120375 Hex Nut
81 51335601
82 513743
83 514690 MARK-Mounted Thickness Planer Feed Motor
84 513406 Planer Feed Motor Mounting Screw
85 502973
86 513735 Planer Feed Motor Retaining Ring
87 513403
88 51341503
89 513411 Planer Control Box Safety Key
90 513760 Planer Control Box Mounting Screw
91 514736
