Find Your Part
- Use the zoom tool, mouse wheel, or pinch to zoom on the diagram.
- Click/touch and drag on the diagram to find your part.
- Click/tap on the reference number in the diagram, or enter it here to filter the parts list table below.
Show Part
Need Help?
Call Shopsmith U.S. Based Customer Care — 937-890-5197Monday - Friday 8:30 am to 4:30 pm Eastern Time.
Email Customer Care — customerservice@shopsmith.com
Parts List:
Ref # | Part # | Description |
135z | 522363 | (incl 136-166) |
136a | 518462 | MARK 7 / MARK V520 Table Rail Connector Tube Lock Knob Return Spring |
136 | 515859 | MARK 7 / MARK V 520/510/505 Table Rail Knob with Stud |
137 | 501637 | Hex Head Screw |
138 | 51410004 | |
139 | 51409702 | |
140 | 426370 | Screw |
141 | 522371 | Front Rail Main Table Assembly (MARK 7/MARK V 520S) |
142 | 515294 | Hex Nut with Star Washer |
143 | 518490 | MARK 7 / MARK V520 Main Table Rear Rail |
144 | 120392 | Flat Washer |
145 | 518460 | MARK 7 / MARK V520 Rail to Table Mounting Flat Head Screw |
146 | 518403 | MARK 7 / MARK V520 Table Spacer for Rails |
147 | 501633 | Washer |
148 | 514620 | MARK 7 / MARK V 520/510/505 Main Table Rear Trunnion |
149z | 514339 | (incl 149-153) |
149 | 514130 | MARK 7 / MARK V 520/510/505 Front Trunnion |
150 | 514340 | MARK 7 / MARK V 520/510/505 Table / Front Trunnion Table Stop Pin |
151 | 514341 | MARK 7 / MARK V 520/510/505 Table, Front Trunnion, Stop Pin Compression Spring |
152 | 514466 | Flat Washer |
153 | 514342 | MARK 7 / MARK V 520/510/505 Front Trunnion Stop Pin Compression Spring Retaining Ring |
154a | 514040 | Pan Head Screw |
154 | 517829 | Button Head Cap Screw |
155 | 514115 | MARK 7 / MARK V 520/510/505 Tie Bar Guard |
156 | 514634 | MARK 7 / MARK V 520/510/505 Main Table Tilt Lock Rod & Shoe Assembly |
157 | 514353 | Rip Fence & Table Tilt Lock Compression Spring |
158 | 518372 | MARK 7 / MARK V 520/510/505 45-Degree Table Stop Bolt |
159 | 514350 | Table Insert Mounting Screw |
160 | 514104 | MARK Clamp Shoe |
161 | 120393 | Flat Washer |
162 | 514311 | MARK 7 / MARK V 520/510/505 Table Indicator Plate |
163 | 514344 | MARK 7 / MARK V 520/510/505 Tie Bar & Tube Assembly |
163z | 514448 | (incl 164-166) |
164 | 514447 | Table Tilt Lock Nut |
165 | 5042559 | Table Tilt Lock Handle |
166 | 502680 | Table Tilt Lock Retaining Ring |
