Note to Admin: ShopTip Videos
Some time ago all of the Sawdust Session Google videos went away due to some problem with Google. The Sawdust Session videos were fixed, but not the ShopTip videos.
Sincerely,
Ron309753
Sincerely,
Ron309753
Sincerely,
Ron309753
Ron309753
A PM would likely work 'more gooder;)/quickly'.letterk wrote:It would be nice if they were in some other format than flash. With the ipad not supporting Flash it makes them hard to watch. I'd love to be able to take my ipad out to the garage and work on my Shopsmith.
I'm trying to locate copies of the video shop tips. They were stored on Google Video which is now defunct.
We didn't see any notification. I expect that Google sent one, but these likely were uploaded from someones non-Shopsmith email account.
I have not found back-up copies of the videos yet.
Shopsmith I.T.
As someone who had Google videos pre- YouTube, I was sent an email that all my videos would be auto converted to YouTube videos and they were. I just don't remember the default sharing permissions of the converted videos. The Google account owner may need to do something.
Please let me know if you need a contact at youtube to help locate and claim the migrated videos.
Perhaps you can check with Nick or Drew? It's likely that Drew uploaded them.
In the meantime, here the Shoptip titles that had Google videos and the corresponding Youtube videos. Can you modify the webpages so that when someone clicks on the arrow to start the video it will open a new window with the Youtube video?
Ten-Cent Mortising Gauge http://www.youtube.com/watch?v=fv-V3zLUJmA
Belt Sander Fence http://www.youtube.com/watch?v=sbdM-bs8j-g
Preventing Router Bit Slips http://www.youtube.com/watch?v=rviSVhx5kqc
Avoiding "Back-routing" http://www.youtube.com/watch?v=yXXjpqxQrUw
Auxiliary Fence for Sliding Table http://www.youtube.com/watch?v=b3pCSG76JR8
Turning Precise Diameters http://www.youtube.com/watch?v=OGUyupl-Nnk
Sanding Plywood Banding hmm, couldn't find this one one Youtube
Zero Clearance Inserts Rats! can't find this one either.
Making Wooden Trivets http://www.youtube.com/watch?v=uygTzLpoStk
Abrasive Cleaning Stick Strike Three!
Using a Boring Bar for Lathe Turning http://www.youtube.com/watch?v=PKL7uMoUR_E
A Long Handle for the Footswitch Dammit, this is getting annoying!
Making Biscuit Joints in the Middle of a Board http://www.youtube.com/watch?v=ufknvWEYlf8
Using a Cone Cutter to Shear on the Lathe Duplicator http://www.youtube.com/watch?v=dXYlarLDasw (note: this is raw video)
Sharpening Knives on the Strip Sander Well, another MIA!
Double Bar Clamp Veneer Press http://www.youtube.com/watch?v=9Jh8N2JyNBE
Lower Saw Guard Maintenance http://www.youtube.com/watch?v=rtRWrAny52k
Aligning a Workpiece for Crosscutting http://www.youtube.com/watch?v=puDvyCfqWPQ
Making Square Corners with Corner Squares http://www.youtube.com/watch?v=XhfLXgyAO58
The Trick to Using Hand Screws Son-of-a...,this one is missing too!
No Slip Glue Tip http://www.youtube.com/watch?v=NLSTsk3Tx1Q
Sharpening Curved Scrapers Well, here's the link, but... http://www.youtube.com/watch?v=7McwpmFZ6Us (this is also covered in SawDust Session 16)
Removing Rust with Potatoes http://www.youtube.com/watch?v=qYgnHDB3VNI
Collecting Sawdust While Drilling http://www.youtube.com/watch?v=duOmbukSZ-A
Lift Assistance for the Table and Headstock No luck on this one!
Stacking Featherboards http://www.youtube.com/watch?v=xY0-79iG9Gw
Cleaning Up Epoxy and Silicone http://www.youtube.com/watch?v=H10al_ELFAY
Undercutting a Tenon http://www.youtube.com/watch?v=JVchU-tKF7M
Curing Planer Woes http://www.youtube.com/watch?v=GFqi_Y4xtUg
Wrapping a Board Around a Box Not to be found on Youtube.
Compound Miters with Sliding Table http://www.youtube.com/watch?v=qwHKtgM9-CM
Waxing Sliding Tables, Clamps, and Jigs http://www.youtube.com/watch?v=QXHK3536ld4
Band Saw Extension Tables http://www.youtube.com/watch?v=3y95p0wXwM4
Sincerely,
Ron309753
Sincerely,
Ron309753
Sincerely,
Ron309753
Ron309753
- camerio
- Location: Valcartier, just north of Quebec City, CANADA
In the apps store, there are some inexpensive flash video converter. Just saying.letterk wrote:It would be nice if they were in some other format than flash. With the ipad not supporting Flash it makes them hard to watch. I'd love to be able to take my ipad out to the garage and work on my Shopsmith.
Camerio
MarkV 520 & Band saw
Thanks for this list of video's. I thought I had seen them all but I now know that is not the case.
While browsing, I found this one that I had never seen and needed to.
Then while continuing the browse with a fresh cup of hot coffee, I found these.
