Neewbie with a Mark V and "stuff"
Hello !! I have purchased a 1981 Mark V and assorted items in an attempt to try woodworking after years of restoring LBC's (Little British Cars) as a hobby. I have been lurking here for a few days getting great help from old posts on alot of questions.
One of the things I can't seem to find an answer to is a problem with the belt sander. The tension knob is stuck...will not turn either way but a tiny bit. the idler drum will not "push back" as it says it should in the instruction book. I've tried tapping it lightly with no luck. It runs fine and belt tracking works fine.
Thanks for any help... I am getting everything cleaned up and adjusted and lubricated ... looking foward to actually put some wood on the metal. :>)
Bill
Bill
This is not an unusual complaint. The belt sander resides in a some what hostile environment. I suggest that it is tiime for a tear down and a thorough cleaning.Billdit wrote:Hello !! I have purchased a 1981 Mark V and assorted items in an attempt to try woodworking after years of restoring LBC's (Little British Cars) as a hobby. I have been lurking here for a few days getting great help from old posts on alot of questions.
Bill
This Sawdust Session should be helpful.
If this does not solve the problem, someone will always be here to answer your questions.
Belt tension
Thanks for quick reply Dusty ! Problem is the belt will not come off due to tension, it will not clear underside of frame. Short of cutting the belt, any suggestions ??
Bill
Bill
Do you know that there is a key or lever built into the tension knob. You press in on that lever to release the tension lock?? Please do not be offended with this question. I don't know what your exposure level is.dusty wrote:This is not an unusual complaint. The belt sander resides in a some what hostile environment. I suggest that it is tiime for a tear down and a thorough cleaning.
MarkFive510
After it 'pops out' push on the idler towards the belt. It should move in. The tracking may be adjusted forwards too far. Rotate the tracking knob top to bottom and you should see the idler drum move inward on that side.
If it has not been lubed/parts moved lately, it may be gummed up. Push harder.
Hard to 'advise' without hands on.
I will say the beast is somewhat counter-intuitive.
Billdit wrote:Thanks JPG ... That was the problem... off brand belt, had been adjusted all the way out... just had to "talk" to it a little bit... Thanks guys !! Now just gotta tear it apart and do major cleaning and lube...
Any suggestions on belt brand ? Which brands to avoid?
Bill
942193 for starters
http://www.shopsmith.com/ownersite/catalog/bs_sandingbelts.htm
Brand x as yer gambling budget allows.
I understand from others here on the forum that the new Shopsmith belts are excellent. I have a stock of older belts (Shopsmith) that I think are excellent. If the new ones are better - WOW - what could you ask for.Billdit wrote:Thanks JPG ... That was the problem... off brand belt, had been adjusted all the way out... just had to "talk" to it a little bit... Thanks guys !! Now just gotta tear it apart and do major cleaning and lube...
Bill
Oh Yeah! I fergit about them greenuns! Cost more, but all rave reviews.dusty wrote:I understand from others here on the forum that the new Shopsmith belts are excellent. I have a stock of older belts (Shopsmith) that I think are excellent. If the new ones are better - WOW - what could you ask for.
They are ceramic abrasive.
