How does your workshop grow?
- paulrussell
I know that everyone has their own specialty when it comes to woodworking, but I'm curious what tools everyone finds to be the most useful in their shops.
I've often heard it said that the tablesaw is the heart of any woodshop, and I have to believe the drill press and sander are close behind. And as Shopsmith owners we all have a lathe.
What tool do you find to be essential to your work? What is surprisingly useful and what do you find gathering dust in the corner?
Paul
520 PowerPro, Planer, Bandsaw, Jointer, Belt Sander, 20" Scroll Saw, Dust Collector, conical disc
Also: 3D printers, and a homebrew CNC
I am a Shopsmith junky. I have a Mark V, a Crafters Station, a jointer, a ProPlaner, a Bandsaw, a Belt Sander and a Bandsaw (I have two) and a Scroll Saw.paulrussell wrote:I know that everyone has their own specialty when it comes to woodworking, but I'm curious what tools everyone finds to be the most useful in their shops.
They all gather dust but not in the corner but rather while in use. The only one that does not get used frequently is the Scroll Saw which hardly ever collects dust because it is under a dust cover.
I find it very hard to say that one is more important to "shop production" than another. They each are there for a specific purpose and none really substitute for the other..
Having fairly recently added a bandsaw to the stable, and used it for a short time, I would have to insert it pretty high on the list. I think the table saw would be first, jointer next followed by the bandsaw then the drill press(both horizontal and vertical mode). Any of the sanders would be next.
Below those in essentially the same 'rank' would be the jig saw and most of the 'other' stuff which have a narrower function and are only needed to perform those operations.
I do not have either a planer nor a dust collector. It I did, they would be near the top also! I be looking!
- paulrussell
I'd never heard of the Crafters Station before. I looked it up on the Shopsmith site ( http://www.shopsmith.com/ownersite/faq/craftersstation.htm ) and discovered that "It's a Complete Snading System"dusty wrote:I am a Shopsmith junky. I have a Mark V, a Crafters Station, a jointer, a ProPlaner, a Bandsaw, a Belt Sander and a Bandsaw (I have two) and a Scroll Saw.
Just goes to show you how much I have to learn. I'd never even considered a dedicated Snading System.
Paul
- robinson46176
I'm just heading out the door as I spotted this. This could be a very interesting thread and I will respond to it better later when I have the time it deserves. For now, while I use the tablesaw a "lot" it is not #1. As a person that has few allergies including any allergies to hand tools I would have to say the #1 tool is the bench... That and a basic set of hand tools. Everything else is just to make it faster or easier.
Maybe the "correct" answer is a Shopsmith...
- curiousgeorge
What's a Snading System?paulrussell wrote:I'd never heard of the Crafters Station before. I looked it up on the Shopsmith site ( http://www.shopsmith.com/ownersite/faq/craftersstation.htm ) and discovered that "It's a Complete Snading System"
George
Ft. Worth, TX.
Go TCU Froggies
Ft. Worth, TX.
Go TCU Froggies
See #2 in the link above!;)curiousgeorge wrote:What's a Snading System?
I would disagree with calling the Crafter's Station a "Sanding Station".
It is more like a Power Station with the ability to host, a Jointer, Bandsaw, Jig Saw, Disc Sander, and Drum Sander. Along with that, it can be set up as a table saw. My setup is now equipped with the 520 rail system. There are three tables (main table, two extension tables).
Shopsmith did not advocate that the Crafter's Station could support a jointer but I will. It runs slower but if you need a jointer and a slow one is the only one -- it works. The trick is simple - feed slower!
I also use mine as the base on which I mount my Incra Fence and Router Table.
It is more than a sanding station. I believe the big reason why it is still not offered by Shopsmith is the fact that it is reversible. Reversible is great for some things (like powering the bandsaw) but a table saw with the blade running the wrong direction is a serious safety hazard.
Started out with an old Rockwell 9" table saw, then a Dewalt scrollsaw. When I bought my 520, my nephew inherited the Rockwell. Over time I have added all of the SPTs except the planer and scrollsaw. I still have a Delta portable (?) planer, but I am hoping to get a stand mounted Shopsmith planer either new or second-hand when I have the cash saved up from my other activities.
BPR
BPR
"Essential" is probably not synonymous with "most used".
The TS is probably the most essential tool. Then the jointer, band saw, sander(s) and router(s). In which order depends on what day it is.
I only do routing on Tuesdays:D
Most used would have to be the benches.
Are appendages and eyes considered tools?
Gene
