Jointer question.
Gene Howe
Jointer question.
Post by Gene Howe »
My present jointer is a 6" 70s vintage Craftsman floor model. Since my shop is a good bit smaller than an airplane hangar, I could use the space the Craftsman takes.
My jointer needs are for edge jointing only.
Would you advise the Shopsmith jointer as a replacement? And, I have two Shopsmiths so, no change overs would be required.
Owner if Bill Mayo has one laying around?
billmayo
Re: Jointer question.
Post by billmayo »
YES. I have a early version joiner that Tony Mann (backhertz) and I rebuild 4-5 years ago and I never used. I recommend upgrading to the new feather guard kit on these joiners. Shipping of this heavy item is very expensive these days.
benush26
Post by benush26 »
Gene.
I am curious as to the depth of the edges you are jointing.
If it is 2" of less have you considered using a router table instead (stand alone or the SS)? A 2" straight bit can be had for < $25. Most router fences can be offset so the following edge can be moved or shimmed to match the edge of the bit. A couple passes and you have a very smooth jointed edge.
That method could free up a fair amount of floor space, just in case the Lear Jet 70 needs a tad more room! :D
Just a thought.
Be well,
Ben
ERLover
Post by ERLover »
Rockler sell a router fence shim wet just for that purpose.
http://www.rockler.com/router-table-joi ... ims-6-pack
Gene Howe
Post by Gene Howe »
Some edges are 3-3/4". Not often, but often enough so that not having the capability would be frustrating.
ERLover
Post by ERLover »
Gene Howe wrote:Some edges are 3-3/4". Not often, but often enough so that not having the capability would be frustrating.
Then I think the SS joiner is the way to go.
masonsailor2
Post by masonsailor2 »
I use my SS fairly frequently and love it. It's not that great for boards longer than 4-5 ft but it is doable. Since most projects are less than that it doesn't come up that often and I have a work around for the longer pieces.
Paul
ERLover
Post by ERLover »
If you go to the SS videos, with Engler he shows you how to make a fence and table extension for a SS jointer, I made the fence extension for more height and length out of 3/4 Baltic Birch, I did not need the table extension, that is a steady pair of hands.
sehast
Post by sehast »
You might try the shopsmith 6" drum sander used with the drum sander fence. The fence has adjustments of 1/64" for both the infeed and outfeed side of the fence so it could be used as a jointer. Takes time to set up but works pretty well, very similar to the router table approach mention earlier.
Gene Howe
Post by Gene Howe »
Thanks for all your suggestions.
Paul (masonsailor) has generously offered to let me have his extra one. So, I am good to go.
