whats the best way
whats the best way
Any one have a way to keep the main shaft on a mkv from turning in the lathe position ?
would like to lock it down while rotating it in different positions .
- BuckeyeDennis
Re: whats the best way
PTWFE has plans for a spindle-indexing apparatus. It’s based on a small faceplate mounted to the aux. spindle. You can find it at the link below by doing a page search for “indexing”.
https://www.shopsmith.com/academy/lathe ... /index.htm
The plans call for drilling a couple of mounting holes in your headstock housing. But on newer headstocks, I’m thinking that would be a fine use for the two holes where the plastic guard for the aux spindle and idler shaft mounts.
This way has the advantage of not being affected by play in the drive sleeve.
http://www.shopsmith.com/ss_forum/gener ... t6075.html
Thanks for the info ! that takes me down a entirely different path then what I had in mind .
I don't know about other models/brands but the back plate on my SuperNova2 chuck has index holes.
Here is my version which has served well over the years.
Paul
Paul
- 4ED57137-EEA7-4B71-B81D-757DCF8E694F.jpeg (220.18 KiB) Viewed 108104 times
- CA527A0C-F441-4502-97A6-F1FAB93CCA3B.jpeg (200.76 KiB) Viewed 108104 times
- 7646DBB6-2F34-46EA-89AE-E6440E0A3C0D.jpeg (181.49 KiB) Viewed 108104 times
looks simple and effective .
Thanks
Thanks
Presented for your consideration
http://www.shopsmith.com/ss_forum/viewt ... 916#p23916
Enjoy your project!
Chris
Enjoy your project!
Chris
Thats different
Thanks !
Thanks !
