Thanks for the reply. I have not checked the thread in a while. I did find out that they are 5/8-11... I tried to use a dewalt LH thread nut, but it only goes on half way. I think you are correct in that the arbor threads are extra tall... Need to find an exact replacement. You should be able to mount a regular sanding disk on the sawsmith arbor. it will lock with the locking screw onto the flat part of the arbor.gavinthegregarious wrote: ↑Wed May 26, 2021 1:58 pmDid you ever get an answer on this. The threads are 5/8-11 UNC but normal 5/8-11 attachments are not fitting. I think the threads on the arbor are extra long/tall which is preventing the normal 5/8-11 nuts and attachments from fitting. I'm not sure though. I really want to get a sanding disc on there.
The Ultimate Sawsmith Radial Arm Saw Thread
Re: The Ultimate Sawsmith Radial Arm Saw Thread
Was able to locate a set of arbor bolts for the saw. Fellow shop smith and saw smith owners are the best!
Thread interference can take place three ways. Pitch deviation is not relevant to this discussion.
The two that are involve the screw clearance between the male and female parts. Both involve the thread 'peak' mating with the mating thread 'valley'. A high peak or a shallow valley creates the interference.
A possible solution requires re threading the parts(a tap or a die). Rust can build up in the valleys so rethreading with a tap MAY 'fix' it. Rust may cause the peak profile to become 'fat' and cause interference so rethreading with a die MAY 'fix' that.
In this case however the SS shaft threads MAY be fatter than typical since it is also an arbor shaft and needs to maintain that 5/8: od. That would require a 'special' threaded nut that has deeper valleys and possibly shorter peaks(like an acme thread peak).
The motor on my 1963 Yuba Saw Smith just burned out and I am not going to spend the $350 to get new windings. I doubt that I can get a replacement motor to fit. If anyone knows a good solution to the motor, please send a reply.
So this is saw is either FOR SALE, or if this website returns a number of requests for parts, I will SELL PARTS for the rest of you to carry on. This machine made almost all the wood furniture In our homes for two generations. It is in good shape with all the parts, lots of blades, some new, good Jacobs chuck, etc.
I am in Dallas Texas. Please contact me by reply if you want to purchase the whole thing or parts. The coil wire in the arm is in good shape, original wood table is in fine shape, as we always kept a 1/4 inch plywood cover nailed on top to do work.
mlwass
mlwass
Was able to locate a set of arbor bolts for the saw. Fellow shop smith and saw smith owners are the best!JPG wrote: ↑Sun Jun 13, 2021 2:04 pm Thread interference can take place three ways. Pitch deviation is not relevant to this discussion.
I'm hoping to get a look at a Yuba Sawsmith RAS just a few miles away. Seller is asking $250, I'm hoping to pay less, but it's advertised with this statement:
"Yuba Saw Smith Radial Arm Saw. Condition is "New". This is a collectors saw or a work horse. This is a barn find. The saw has never been used. Comes with original tag to mail back into Yuba"
eBay ad here: https://www.ebay.com/itm/313573602090?ul_noapp=true
Any opinions on what this is worth if it's actually in 'new' condition?
For starters it ain't in "new" condition. It is a restore project. Maybe not used, but not stored well either.
I would not pay more than $150 for it and I would like to have one.
I made an offer of $150, mainly just to send him a message telling him I wanted to see it. I am skeptical about the condition. My wife looked on Facebook and saw them advertised for prices from under $100 to over $1000. I need to see it and give it a chance to tell me about it's condition.
In March, I got my saw for $75 and it was not working. It needed a new capacitor and did not have the 5/8 inch arbor nuts on it. The arbor spindle is 5/8 inch like the shopsmith and the normal arbor takes blades that have a 1.25 inch hole. I would read the area in this thread about selecting blades for this saw too. Also check to see if the switch keys are there. There is a lock on top of the saw. Hope this helps. I am still working on mine, but the motor fired up with a new capacitor and lubrication to the sheeve (like a shopsmith).edma194 wrote: ↑Thu Jun 24, 2021 7:49 pm I made an offer of $150, mainly just to send him a message telling him I wanted to see it. I am skeptical about the condition. My wife looked on Facebook and saw them advertised for prices from under $100 to over $1000. I need to see it and give it a chance to tell me about it's condition.
Thanks for the advice. I should be able to see this machine soon. The condition is critical, if it's missing important parts or the motor isn't working I see significant cost to make this usable. Since I wouldn't use a RAS that often I don't know if it would be worth it. I'm not sure if my offer was accepted just so he could tell me where he lives, apparently ebay has a rule against sharing addresses and phone numbers without an accepted offer. If he wants more for it then I'll probably have to pass based on JPG's suggestion that it's only worth $150. I'll take a look at it and get the low down.delong94 wrote: ↑Fri Jun 25, 2021 2:27 pm
This machine is mine now. The story is that it was never used and the indications are pretty good that is correct. No cuts in the table, no sawdust anywhere. Mild corrosion on the cabinet and post. Plenty of grease on where it mounts to the post. The motor turned right on and the speed control works. The keys were in the lock. Everything else seems functional, has the original blade mounted on the left. Does not have the right side arbor nut but does have the rubber cap. Finding a nut for the right side doesn't seem like it will be a problem. The tabletop needs replacing, probably use some MDF I already have for that. Have to do some other things over the weekend but will take some pictures before long to post.
