Sometimes a 4-Inch Drum Sander is just the ticket
nuhobby
Post by nuhobby »
And you probably have one! Strip sander, that is...
I was refurbishing a very old cross-peen / riveting / tinsmith hammer. The new hickory handle is very taut, and has a nice curve faired-in with the help of the strip sander:
4 Inch Drum Sander.JPG (98.44 KiB) Viewed 20121 times
Old Hammer New Handle.JPG (140.4 KiB) Viewed 20121 times
Happy woodworking!
Chris
Re: Sometimes a 4-Inch Drum Sander is just the ticket
Nicely done! :)
Now why is fairing desirable? :confused:
JPG wrote:Nicely done! :)
Elegance and esthetics. That was important back in the old days. I remember the old days (not too old :eek: ) as I am sure you do. :D :D
ChrisNeilan
Post by ChrisNeilan »
Plus 1 :)
Chris Neilan
I unnerstan the reason for fairing on a boat hull, but a hammer handle? :rolleyes:
nuhobby
Post by nuhobby »
The taper in the handle feels "right" for how some hammers get used. Sometimes the operator wants to "choke up" toward the head for a bit more control (and less power), so a narrower section helps with that.
The other cool thing is having a smooth, oil finish. Typical thick factory varnish can be abrasive to the hands.
If you haven't put a new handle on a hammer, I recommend trying it! It's really satisfying, particularly if the factory handle has come loose some.
Chris
It's also a great way to save an old hammer head you may not be able to replace with a new one.
All SPT's & 2 Power Stations
