phone  (937) 890-5197
Shopsmith Forums
%nbsp;
21 posts 1 2 3
Re: metal toggle switch--how old?
#259530 by WileyCoyote » Fri May 10, 2019 5:04 pm
If properly cleaned and waxed, they all sink unless you hold pressure on them.
#259532 by reible » Fri May 10, 2019 5:52 pm
You can snug up the wing nut so the table will pretty much stay in place yet allow you to still move it as needed. If the nut is loose then yes it will fall, and if it doesn't it should.
#259777 by james1726 » Mon May 20, 2019 7:57 pm
It sinks. I try to have just enough tension to keep it fairly in place while i'm trying to line up for horizontal bore but a smidge to loose and it's gona sink
#259780 by rpd » Mon May 20, 2019 8:42 pm
james1726 wrote:It sinks. I try to have just enough tension to keep it fairly in place while i'm trying to line up for horizontal bore but a smidge to loose and it's gona sink
An option is to use the micro adjustable stop collar. :)
https://www.shopsmith.com/ownersite/catalog/swd_adjustablestopcollar.htm
#259781 by jsburger » Mon May 20, 2019 8:46 pm
That is absolutely the answer. They work perfectly and you will not regret spending the money.
#259783 by sfwood » Mon May 20, 2019 9:33 pm
Actually got one of the micro-adjust gizmos in the box-o-parts with the used Shopsmith. Just need to figure out how to use it. :--)
Thanks
#259784 by james1726 » Mon May 20, 2019 9:54 pm
Very interesting. I have not seen that before
#259788 by adamkearns » Tue May 21, 2019 5:12 am
As far as I know, they should be lowered slowly if there is no bracket. Also, if there are bolts inside, you can heat it up with the help of a Heat Gun (like this one https://protoolsadviser.com/best-heat-guns/), metal will expand and maybe it will fall into place.
#259801 by chapmanruss » Tue May 21, 2019 12:09 pm
sfwood wrote:Actually got one of the micro-adjust gizmos in the box-o-parts with the used Shopsmith. Just need to figure out how to use it. :--)
Thanks
If you go to the Support page under Online Manuals you will find the instructions in the AdjustingCollar.PDF or use this link https://www.shopsmith.com/ownersite/productmanuals/AdjustingCollar.pdf
Mark V 520 S/N 09-11-01 completely upgraded to Mark 7, with all SPT's & more.
Model 10ER S/N R64000 first one I restored on bench w/ Shopsmith metal ends & retractable casters. Has Speed Changer, Model 4E Jointer, Jig Saw with lamp, a complete set of original accessories & much more.
Model 10E S/N 1077 oldest one I have restored. On bench w/ Shopsmith metal ends & retractable casters.
#259803 by jsburger » Tue May 21, 2019 12:44 pm
adamkearns wrote:As far as I know, they should be lowered slowly if there is no bracket. Also, if there are bolts inside, you can heat it up with the help of a Heat Gun (like this one https://protoolsadviser.com/best-heat-guns/), metal will expand and maybe it will fall into place.
SPAM!
Who is online
Users browsing this forum: No registered users and 35 guests
Welcome to Shopsmith. Please fill in this form and we'll send you more information about the Shopsmith MARK 7 and other woodworking topics.
Subscribe to our mailing list
* indicates required
