phone  (937) 890-5197
Shopsmith Forums
%nbsp;
109 posts • Jump to page: 1 7 8 9 10 11
Re: V-belt replacement
#258122 by jsburger » Mon Mar 18, 2019 8:31 pm
JPG wrote:
BuckeyeDennis wrote:
JPG wrote:... I do not like things I do not completely understand.
Then I must assume that you don't like women! :D
Touche!
In that case it is a part time thingie. :D
You just have to understand the one you like. :eek: :D
#258124 by JPG » Mon Mar 18, 2019 8:42 pm
Touche!
Like I said, part time. 49 years and counting so far! :D
Goldie(Bought New SN 377425)/4" jointer/6" beltsander/12" planer/stripsander/bandsaw/powerstation /Scroll saw/Jig saw /Craftsman 10" ras/Craftsman 6" thicknessplaner/ Dayton10"tablesaw(restoredfromneighborstrashpile)/ Mark VII restoration in 'progress'/ 10E(SN E3779) restoration in progress, a 510 on the back burner and a growing pile of items to be eventually returned to useful life. - aka Red Grange
#258127 by roneg » Mon Mar 18, 2019 8:52 pm
JPG wrote:Take another showing the idler sheave and back towards the rear end of the idler shaft. Should show idler sheave, gilmer pulley/belt and casting with retaining clips.
I notice a couple of things(not necessarily related to belt problem).
The casting is fractured and apparently a piece is resting on the quill in the first pix.
The seal material from the idler bearing is coming loose?
No JPG there is no fracture it is deceiving. I think because this is one of the original sand castings the area is just naturally rough. Also, no not a idler bearing coming apart..again deceiving. That is a flat piece of steel that goes from the nut to the top if the idler shaft eccentric bearing
"The older I get..The better I was"
#258128 by jsburger » Mon Mar 18, 2019 9:00 pm
JPG wrote:
jsburger wrote:
JPG wrote:
Touche!
:D :D :D :D :D :D
#258130 by JPG » Mon Mar 18, 2019 9:07 pm
Sheez I should have recognized those two clips. :o
It looked like a loose piece was laying on the quill - camera angle!
So that is all good news.
#258131 by roneg » Mon Mar 18, 2019 9:30 pm
Better news. It is all back together and running fine...so far😁 New power cord, new main belt, new re-built control knob. Because I stripped the cheesy aluminum gear on the old one!. Lastly new on/off switch. Oh..all new belt cover,motor pan, and motor mount screws. All I can say is who ever designed these greenies must of had needle nose hands! Long ones!🙁
#258132 by roneg » Mon Mar 18, 2019 9:32 pm
roneg wrote:Better news. It is all back together and running fine...so far😁 New power cord, new main belt, new re-built control knob. Because I stripped the cheesy aluminum gear on the old one!. Lastly new on/off switch. Oh..all new belt cover,motor pan, and motor mount screws. All I can say is who ever designed these greenies must of had needle nose hands! Long ones!🙁
#258134 by JPG » Mon Mar 18, 2019 9:32 pm
Great news!!!!!!
#258135 by roneg » Mon Mar 18, 2019 9:42 pm
I might need to set the high speed stop again that is all no biggie. After putting on, and taking off the knob on the the control assembley a hundred times! It must have got changed somehow. As it will run to slow but doesn't seem to run to as fast as it was when I set the high speed stop screw.
#258149 by JPG » Tue Mar 19, 2019 1:06 am
The 'slow' limit is when the control sheave bottoms out against the idler sheave(idler pulley fully closed and the belt riding highest).
The high speed stop establishes the 'fast' limit. The limit prevents the control sheave interfering with the speed control frame.
The indicator ring merely goes along for the ride as the control knob is rotated. i.e. it indicates knob rotation rather than the actual speed.
Who is online
Users browsing this forum: Google [Bot] and 52 guests
Subscribe to our mailing list
* indicates required
