phone  (937) 890-5197
Shopsmith Forums
%nbsp;
11 posts 1 2
Sawsmith 2000 (not RAS) owner is looking for some parts.
#164705 by crabsaw » Wed Apr 02, 2014 10:09 am
Hi Folks,
I am new to the forum.
I have owned my Sawsmith 2000 for about 6 months or so now. It needs some parts.
I think this saw is almost perfect. I have realized there is barely any support or parts for this thing. I would love to "restore it" and use this piece of equipment.
The bad:
1.)The "carriage lock thread " that holds the saw in place (not the spinner that locks) but the actual plastic threaded piece that the "pole" goes into and the spinner locks in with force was broken. I "fixed" with JB weld. I am not too comfortable about the fix. It works but like I said it was JB welded. I am looking into machinists or maybe it can be 3d printed. dunno..
2.) Miter gauge that came with it is not original. I have on on the way and understand the 510 miter gauges are compatible with the 2000.
3.) The Bevel lock was broken, fixed with JB weld but would like to find a replacement.
4.) The wheel that aligns the bevel is broken off. looking for a replacement or engineer something.
5.) Not sure how the blade guard goes in. (really need a manual)
6.) Excalibur fence needs tweaking is not totally aligned.
The good
1.) overall it seems to run fine cutting what I need it too.
2.) dado arbor and accessories are all there.
3.) have miter stops
Any help and insight is greatly appreciated. My apologies for not using proper SS nomenclature.
Thanks,
Crab
#164706 by crabsaw » Wed Apr 02, 2014 10:11 am
More pictures.
#164712 by steve4447 » Wed Apr 02, 2014 10:34 am
Looks like a great project...
#164739 by crabsaw » Wed Apr 02, 2014 3:11 pm
I think it is a good project too however, I do not think I have ever owned/restored something that had parts that were so hard to find.
I will probably wind up fabricating parts for it :-(.
Anybody have a manual I can buy off of them for this piece?
Who owns these things?
How did the SS 2000 become such a lost cause?
I am still hopeful :-)
G
#164740 by henecle » Wed Apr 02, 2014 3:12 pm
Here you go... Link for purchasing the manual from Shopsmith (if still available)
http://www.shopsmith.com/ownersite/itemfind.htm?item=556080
Sawsmith 2000 FAQs
http://www.shopsmith.com/ownersite/faq/sawsmith2000.htm
As earlier stated, parts availability is next to nil, SS did a fire sales on the last of the parts they had for the Sawsmith 2000 a few years ago. Only common parts with other existing SS systems might still be had (not many of those either). The biggest challenge will be fashioning a solution to lock the blade into one position along it's range of travel front to back.
Leif
1981 Mark V Model 500 "Shorty"
1981 Mark V Model 500 "Drill Press"
1987 Sawsmith 2000 Ultra
2005 Mark 7 PowerPro Model 520/Bandsaw/Jointer/Pro Planer/Belt Sander/Scroll Saw/Jigsaw/Strip Sander/Universal Tool Rest/Speed Reducer/DC3300/RingMaster/Mortising Package/MiterSled 5000/Biscuit Joiner/Grinding Wheel Guard/Nova G3 Chuck/Lathe Duplicator/SS Air System
2010 Lumber Smith sawmill
CarveWright CNC
"I wish I could remember everything my Dad taught me"
#164741 by crabsaw » Wed Apr 02, 2014 3:17 pm
Thanks a lot for the information.
I was able to fix the threaded lock and it does lock and I have tested but like I said how long can I trust JB weld right.
This thing is built so tough but one of the main components (locking mechanism) is cheap plastic.
I have a miter on the way so I can utilize the RAS type feature.
Looks like I can buy the manual.
thanks again I have only "met" two other people on the net that have this thing.
Thanks,
Crab
I just pick one up yesterday. Same thing, the Cambridge plastic broke, as soon as I turned it. So brittle. Also, can you look at the start capacitor, as mine is missing and I have no clue to what size or what wires plugin to what.
Thanks for your help
The capacitor on my Sawsmith 2000 reads as follows
Aero M
161 - 193 MFD
110 V
677-9110-02
FSA1R10161N ( I think)
orange & maybe red go to capacitor
Glenn
SS 520 born 04/16/03, Power Station mounted Band saw , Scroll saw, Jointer, Belt sander, Overarm router, SS Sawsmith 2000, dedicatedted Mark V drill press, DC3300, SS Maxi-clamp system, Shopsmith woodworking bench
Stumpbuster wrote:The capacitor on my Sawsmith 2000 reads as follows
Aero M
161 - 193 MFD
110 V
677-9110-02
Thanks. That appears to be the same capacitor as used on many of the Mark V motors. I hope to see the 2000 later this week.
I've been repairing some of the problem parts you mentioned by reverse engineering and then designing them in CAD and printing them with ABS plastic on my 3D printer. (I know the original post was 6 years ago, but in case new folks are coming here...)
Here are some of the parts I've successfully designed and replaced on my system. While 3D printed ABS is pretty strong, it is somewhat sensitive to threads tear-out due to it not being the much harder material that used for the the original parts. That being said, it is working as long as I don't over tighten.
SAWSMITH 2000 Carriage Locking Collet 516457
SAWSMITH 2000 Carriage Collet Plate 516459
SAWSMITH 2000 Replacement for
In development
I'm also currently testing a beefed up bevel lock to replace my cracked one (like the original poster, I JB welded mine and added a narrow hose clamp for extra strength.)
The new one is beefier on the twist paddles and the overall thickness and the shaft region with the 3/4"-10 threads. I will post how it turns out. Pictures are attached.
You can find my at chadwallsvcs.com. Just submit a contact me note and we can see if I can help out.
Best Regards,
Chad
SAWSMITH CARRIAGE LOCKING COLLET 516457.jpg (219.31 KiB) Viewed 970 times
SAWSMITH CARRIAGE COLLET PLATE 516459.jpg (115.81 KiB) Viewed 970 times
516457 AND 516459 INSTALLATION
CARRIAGE COLLET PLATE AND COLLET.jpg (402.65 KiB) Viewed 970 times
ISOLATOR 517988 - RETROFIT KIT
ISOLATOR 517988 - RETROFIT KIT.jpg (559.4 KiB) Viewed 970 times
BEVEL LOCKING HUB - 516458 - IN DEVELOPMENT
BEVEL LOCKING HUB - 516458 - PENDING.jpg (592.31 KiB) Viewed 970 times
Who is online
Users browsing this forum: No registered users and 148 guests
Subscribe to our mailing list
* indicates required
