phone  (937) 890-5197
Shopsmith Forums
%nbsp;
3 posts • Page 1 of 1
ECCENTRIC TUBES
#274574 by FraudDog » Thu Sep 17, 2020 7:50 pm
Told you all I would have a lot of questions!
Are all of the eccentric tubes that are used for mounting sander, planer, band saw the same? I am short two of them.
Thanking everyone for their patience, and assistance.
Re: ECCENTRIC TUBES
#274579 by DLB » Thu Sep 17, 2020 11:01 pm
No, they are not all the same. Also some old ones are not eccentric. The belt sander and bandsaw can use the same eccentric tubes IIRC. I don't have a SS Thickness Planer but I believe it has a unique mount, no eccentric tubes. The Jointer, sometimes called a Planer, uses much shorter eccentric tubes.
Ideally you don't want to share mounting tubes even if they are the same, such as Bandsaw and Belt Sander. They should be adjusted for each tool so it is best if they stay with the tool. It is okay for short term, of course.
Re: ECCENTRIC TUBES
#274594 by chapmanruss » Fri Sep 18, 2020 2:57 pm
David is correct there are different length tubes and the Mark Mount Planer rests on the Way Tubes. Some do use the same posts such as the Band Saw and Strip Sander for example. As David said it is best that each SPT has it own posts otherwise you will have to align the tool each time the posts are switched and used.
All SPT's & 2 Power Stations
Model 10ER S/N R64000 first one I restored on bench w/ metal ends & retractable casters. Has Speed Changer, Model 4E Jointer, Jig Saw with lamp, a complete set of original accessories & much more.
Model 10E S/N 1077 oldest one I have restored. On bench w/ metal ends & retractable casters.
Who is online
Users browsing this forum: Bing [Bot] and 132 guests
Subscribe to our mailing list
* indicates required
