Save 15% on everything you need! SAVE NOW
Table Storage System
555941
$79.95
$67.96
SAVE 15%
The Table Storage System (for All MARKs except MARK V 500) (555941) holds your MARK tables, connecting tubes and legs for storage until you are ready to use them again. If you like being organized and believe that there should be a place for everything and everything in its place, this table storage system is for you.
Carefully engineered for strength and convenience, the rugged, extruded aluminum brackets will store your worktable, two floating tables, four connector tubes and a pair of telescoping legs out of the way when not in use. Just mount the two brackets to a piece of scrap wood (not included), attach the assembled system to the wall at a height that's comfortable for you - and you're done.
Slide your worktable onto the 45-inch-long mounting tube (included) and hang it over the lower bracket arms. Then slide on your two floating tables and telescoping legs. The four connector tubes drop right into the open top of the upper bracket arms.
Includes: • (2) Aluminum, Black Painted Brackets • 45-inch Mounting Tube • (4) Mounting Screws and • Full Instructions.
