top of page
Super Spindle 10-Piece Chisel Set
SKU 556483
556483
Price
$259.95
Made from High-Speed Steel or Carbon, these Chisels are made to last. They come in a protective case or wrap and are a great complement to your Shopsmith Equipment!
Benjamin's Best 8-Piece Chisel Set Brought to You by Shopsmith (556484)
Universal 8-piese set of Lathe Chisels for bowls and spindles. A great set to satisfy the majority of your turning needs. Each chisel features a premium-quality, high-speed steel blade to take and hold a keen cutting edge under hard use. This blade is set in an ergonomically-designed hardwood handle and reinforced with a brass ferrule for added strength and durability.
8-Piece Set includes:
� 3/16" Parting Tool for roughing-in large turnings and cutting large coves in both spindle and faceplate projects
� 5/8" Spear Scraper
� 5/8" Skew Chisel
� 1" Skew Chisel with a straight, slanted edge and a sharp point for shaping straight profiles, forming beads and getting into tight areas on spindles, bowls and more
� 1/2" Bowl Gouge
� 5/8" Roundnose Scraper for cove work on both spindles and faceplate turnings
� 3/4" Spindle Gouge with a pointed tip for grooving, cutting shoulders, sizing and separating the finished workpiece from the scrap
� 7/8" Roughing Gouge
� PLUS a Handsome Wood Storage Case � FREE!
Super Spindle 10-Piece Chisel Set Brought to You by Shopsmith (556483)
Versatile set of turning tools for most types of spindle work. Ideal for smoothing, detail cuts, roughing, and parting; Use for making anything from delicate finials to pens or baseball bats. This Set includes (10) turning tools with ergonomic handles, a wood storage case, a star key, and a how-to guide for using each tool; Carbide cutters on (2) tools; M2 High Speed Steel cutting tips on (8) tools.
The following (5) Turning Tools have M2 High-Speed Steel cutting tips and measure 16" in total length with 6-1/2" blades and 9-1/2" hardwood handles:
� 1" Roughing Gouge
� 5/8" Skew Chisel
These Miniature Turning Tools feature M2 High-Speed Steel cutting tips � (2) measure 10" in total length with 4" blades and 6" hardwood handles, (1) Tenon Tool measures 9" in length with a 5" blade:
� 1/4" Mini Spindle Gouge
� 1/4" Mini Skew Chisel
� 1/16" x 1-1/4" Tenon Tool
The (2) Carbide-Tipped Turning Tools with replaceable cutters measure 13-1/2" in total length with 3-1/2" blades and 10" hardwood handles:
� 3/8" Square 2" Radius Cutter used for roughing and shaping
� 3/8" Super Skew used for shearing
Benjamin's Best 3-Piece Carbide Wizard Chisel Set Brought to You by Shopsmith (556463)
Now you can get all the benefits of carbide with the value and performance of Benjamin's Best. With their super sharp carbide cutters and custom designed ergonomic handles these chisels will wiz through your material for faster results and eliminate the need for sharpening. Guaranteed to last 20 times longer than high speed steel. When the edge does get dull, just spin the tip to a new position. The tips are also easy to replace and interchangeable with a Star lock style screw & wrench. You get 3 high performance chisels with 4 profiles. Square Cut Chisel: With its 3/8in. square cutter you'll be able to quickly rough your pen blank and remove material in bulk. Rotate the cutter to use the gentle 2in. radius, you'll get a super smooth final profile and finishing. Cover Cutter Chisel: The round cutter on the Cove Maven will allow you to turn coves, hollow out bowels and finish the inside of bowls. Detail Chisel: Ideal for small, intricate work and cutting final details on your projects. Perfect for small coves and beads on pens. All 3 chisels in the set are 13-1/2in. long with a 4in. blade and includes a wood carry case. (Magnetic chip deflector sold separately).
Benjamin's Best High-Speed Steel Inboard Bowl Scraper 2-Piece Set Brought to You by Shopsmith (556485)
Ideal for bowl turning and deep hollowing. These heavy duty round end inboard side scrapers are equipped with thick, stable blades so you can cut aggressively without vibration. Create a clean smooth finish.
Specifications
Super Spindle 10-Piece Chisel Set Includes:
� 1" Roughing Gouge
� 5/8" Skew Chisel
No Reviews YetShare your thoughts. Be the first to leave a review.
Frequently Bought Together
bottom of page
