Weekly Shopsmith Deals! SAVE NOW
Lift Assist with PowerPro Upgrade (for MARK V's manufactured before 1972)
$309.95
Shopsmith Lift-Assist Reduces the Effort Required to Raise your MARK into Vertical Position to as Little as Zero! \n \nIt is not always easy repositioning well made, reliable equipment such as a Shopsmith MARK, but it's IMPORTANT! Shopsmith has created a way to make sure every Owner can move their MARK with great safety, ease and efficiency, all while guaranteeing that these quality products remain durable, rugged, and sturdy. That's why the Shopsmith Lift-Assist is the Perfect Accessory! \n \nThe Shopsmith Lift-Assist offers instant ease in turning Your Machine from a horizontal to vertical position, removing extra effort and time while still allowing you all the functionality of the hard-working MARK that you know and love. \n \nLIFT-ASSIST PACKAGE INCLUDES: \n� Lift Assist Arms - Gas Charged Cylinder \n� Hardware \n� Simple, Step-by-Step Instructions for adding it to every MARK Model \n \nPounds of Lift Effort Required With & Without Shopsmith Lift-Assist \nSmart Motor Distance from Left Side of MARK - Pounds of Effort Required Without Lift-Assist - Pounds of Effort required With Lift-Assist \n0" 65# 25# \n8" 57# 20# \n12" 50# 12# \n20" 35# Self-Lift \n \nNote: If you own Shopsmith's steel storage cabinets, with the lift-assist only one of them will slide under the MARK 7 / MARK V for storage (if the casters are removed from the steel storage cabinets, two will fit). \n \nMARK 7 / PowerPro Lift Assist Gas Cylinder Upgrade \nShopsmith offers an upgraded Lift-Assist with a design optimized for the PowerPro Smart Motor, which is ten pounds heavier than a conventional MARK V Smart Motor. \n \nThis upgraded Lift-Assist also provides a quick disconnect which allows the MARK 7 to be easily tilted left for under-table operations. Shopsmith also offers a cylinder upgrade to add these capabilities to an existing Shopsmith Lift-Assist. \n \nAnother MARK Owner Favorite!
